Bark removal tool recommendation?
Discussion in 'Axes, Mauls, and Hand Saws' started by buZZsaw BRAD, Nov 14, 2020.
  1. buZZsaw BRAD
    Back a while ago there was talk about what they used for removing loose bark from round/logs etc. I was using my $3 cheapo machete today to remove bark from dead ash i was scrounging.
    Ms. buZZsaw just asked what i wanted for Christmas and a MS500i was out of the question.
    What do you use/suggest FHC? Pics helpful.
    Chazsbetterhalf and M2theB like this.
  2. MikeInMa
    Chazsbetterhalf likes this.
  3. MikeInMa
    That's a bark spud from Tractor supply. The link wouldn't post here for some reason.
  4. huskihl
    huskihl
    Look up Log Wizard
    Chazsbetterhalf and buZZsaw BRAD like this.
  5. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    And there’s another tool I didn’t know I might need.
  6. buZZsaw BRAD
    Cool tool but looking for a simple hand held for when i get dead wood.
  7. metalcuttr
    metalcuttr
    western WA
    Wonder how a small hand adz would work?
  8. Paul bunion
    Paul bunion
    For log length on the ground with loose bark (maybe a layer of punk) a good hoe does the trick.
    A Rogue Hoe Travis Tool meets the bill. For debarking you get a broad and narrow cutting edge with the Travis Tool. It is also a rake, tamper and has an edge for moving dirt (chips). Its made from a plow blade. There are other Rogue tools with an equally nice edge.
  9. Cheepbeer
    Cheepbeer
    NW Ohio
    The easiest way I found to debark is drag ‘em.
    Well, it’s a little simple and hand held...when you’re hookin’ up the chain.
  10. M2theB
    M2theB
    Central Massachusetts
    Your adding one more step to a process that I’m trying to limit.
    split and aged before final stacking, bark often falls off when tossed into the shed. I hunt old blow downs or standing dead, so it’s a head start with respect to bark.
    stacking bark side down should have a similar effect, covered with an air gap.
  11. buZZsaw BRAD
    Some instances the wood i scrounge has the bark loose enough to come off. It was easier and less mess here, to do it there. Not something ill intentionally do. If it comes off when unstacked thats good too.
  12. buZZsaw BRAD
    Im leaning toward the Fiskars 18" machete hatchet. Anyone own/use one?
    Chazsbetterhalf and metalcuttr like this.
  13. buZZsaw BRAD
    Just made an offer on one on ebay and the guy accepted $32
  14. Mag Craft
    Mag Craft
    South East Wyoming
    If I am going to mill a log and want to remove bark first I use a draw knife.
    If I am getting rid of loose bark on rounds that I am going to split I use a hatchet that is very sharp.
  15. buZZsaw BRAD
    It came today. $32 ebay new out of package. Havent tried it yet. IMG_3508.JPG
  16. MikeInMa
    All ready for the zombie apocalypse!
  17. buZZsaw BRAD
