Bar sprocket grease?
Discussion in 'Chainsaws and Power Equipment' started by HDRock, May 23, 2014.
  1. HDRock
    Maybe I will clean em up, shoot some brake cleaner through them ,then some air and let the oil do the lubing after that
  2. Boog
    Boog
    Where my spirit is free
    WD 40 for me. Give a little spritz in there every time I clean the bar, and then spin the sprocket a few times. Seems to work just fine and I have never noticed any type of a buildup issue after "heating up" a bar.
  3. bogydave
    My POS , Husqy, needle tipped, grease pump works fine for me.
    I pump grease in from a grease gun & let the grease push the grease gun tip out,
    with no air, or air pockets, it seems to work for me.
    HoneyFuzz likes this.
  4. papadave
    When you come to a fork in the conversation....take it.
    $ooline and Locust Post like this.
  5. Locust Post
    Or you could take your fork and clean the saw dust out of the greased sprocket. I also have a POS Husky grease gun that works real fine. :popcorn:
    HDRock, HoneyFuzz and papadave like this.
  6. clemsonfor
    I bought an oregon gun on clearance at walmart.
    Stihl bars are sealed and you dont grease them.
    I have asked a few loggers I deal with how often they grease their saw bars, as 95% run husky and husky bars. Most say every so often, or their suppose to everyday. Personally all the time I spend around them I can't say I have ever seen one grease a bar , but if they do it first thing in mourning when they get there I would not see it anyway. I have however seen saws in the back or trucks or in tool boxes with grease at the tip like they were filled before put away, and all have the guns, so they do it at some point??
  7. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I use the good Oregon grease gun myself. I have always greased.. Because they give a hole to do so. Never thought about not doing it :)
  8. MasterMech
    Does anybody know if the higher-end bars from non-OEM sources (Sugihara, Tsumara, Total, Cannon, etc.) have provisions to grease the nose sprockets?
    papadave likes this.
  9. nate
    nate Banned
    Palmer, AK
    I've had trouble with that little sprocket bearing burning up, even when greased. Went though 3 or 4 of them last year between the 2 saws. They aren't very cheap either, around $15 if I remember correctly.
  10. clemsonfor
    I thought you ran stihl bars Nate...there non greased tips?
  11. DexterDay
    DexterDay Administrator
    Northeast Oh
    That doesn't mean you can't grease them.
    I stihl (;)) grease mine every so often. When the bar is off and I blow them out, I will push some in between the teeth and rotate, put some in between the teeth and rotate. It definitely can't hurt.
  12. clemsonfor
    I get your idea but I certainly dont go to all that trouble.
    Cleaning the bar for me means taking the scrunch and running g it down the bar grove to clean it out every so often. I bet the oil would flow a bit better if I blew them out a few times a year with compressor.
  13. basod
    basod
    Mount Cheaha AL
    I actually greased the roller nose on the MS170 the other day after it locked up:whistle:... This saw was a flood victim and hadn't really run it much until recently - thought at first the chain brake was messed up but after stalling the chain several times found the roller locked up, a little Kroil and it was back in business
    HoneyFuzz, HDRock and clemsonfor like this.
  14. redneckdan
    redneckdan
    Northern Minnesota
    HDRock likes this.
  15. clemsonfor
    Funny this post just notified me cause I just walked out of TSC and had to buy a grease gun busted a few times ago.
    Also bought 2 gallons of the bar oil on sale for $7!!:)
  16. redneckdan
    redneckdan
    Northern Minnesota
    Just grabbed four jugs from Menards at $4.50 a jug in sale.
  17. clemsonfor
    :doh: But we dont even have one of those within like 8 hours of here.
    If it weren't for the internet and forums and google i wouldnt even know that place existed!
    $ooline and HDRock like this.
  18. HDRock
    That's funny I bought a grease gun when I was there the other day also
  19. HDRock
    was that a gallon jug?
  20. clemsonfor
    My other one fell apart..i think out was an oregon I got on sale at walmart years ago...before I had a bar to grease. I use to just have stihl bar.
    HDRock likes this.
