Bar oil bend over
Discussion in 'The Wood Pile' started by jrider, May 4, 2020.
  1. jrider
    jrider
    Got 4 gallons of county line this afternoon for $36 with tax. That’s my best option
  2. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    Ouch! Did they at least use a little bit of the bar oil when they bent you over? :rofl: :lol:
  3. TurboDiesel
    Yikes!
    I swear Steahl oil goes up a dollar every year!...Screw them!
    I got the Rural King or TSC brand last time at $5
  4. Farmchuck
    Farmchuck
    Nepa
    When I started cutting firewood I remember Husqvarna bar oil was $4.99 a gallon or $24.00 for a case of 6 ! Guess we won’t be seeing those prices again.:(
  5. Farmchuck
    Farmchuck
    Nepa
    Right now I’m buying Itasca at the local mom & pop hardware store. $48.00 per case (6 gallon) I know I could get it cheaper other places but it’s good quality oil & I like supporting local. They’ve been there since 1903 & I know it’s a struggle for them to hang on in the corporate run world we live in these days. If it costs me a few dollars here & there to help keep them going I figure it’s well worth it. When places like that go I fear they’ll be gone forever.
  6. Andimus Prime
    Andimus Prime
    NW NC
    My local Stihl dealer stopped carrying the Stihl brand because it was so expensive :makeitrain"
  7. Farmchuck
    Farmchuck
    Nepa
    Now $23.99 a gallon is another story all together. To rich for my pockets as well.
  8. WoodPirate
    WoodPirate
    Tennessee
  9. FatBoy85
    FatBoy85
    Washington State
    Yes you can even use spent peanut oil from say your turkey fry as well but this would be when you’re running your saws so often, it’s not giving it time to sit in as you observed, don’t use it your tank in temps lower than 40°.
  10. The Wood Wolverine
    You can run brake fluid... or used motor oil. I'm not trying to be a Debbie-downer but I wouldn't even consider it. These liquids are not designed to do the job, no additives to keep it on the chain when it's at speed going around the tip. I used a non specific "motor" type oil (mobil DTE) and it slung off. Long story short, I watched used printing press oil be wasted enough times I decided to try it. I now have a 37" bar that is unusable. I see proof of extreme heat due to lack of lube. My mistake, won't make it again. And if I can help prevent someone else from doing it... I will. Maybe a small bar with light use?
    My question is, why not use canola in you car? It's cheaper. :D Why treat your saw any less?
    If anyone takes that as a rant, I'll apologize. Wasn't intended as one. Just sharing my experience.
  11. FatBoy85
    FatBoy85
    Washington State
    No I got this info off a chainsaw group and people were using it left and right as a backup, mostly in the summer time because it would just be used up and I guess they ran it through their saws NBD. I wasn’t them. Use it in a pinch? Sure but definitely not recommended as a surefire thing. :yes: I’d only use it on a very cheap saw, maybe a trimmer only.
  12. Backwoods Savage
    They also used to mix in kerosene.
  13. FatBoy85
    FatBoy85
    Washington State
    For lamps?
  14. Backwoods Savage
    :rofl: :lol: Well, yes, but also mixed it with bar oil when it got really cold outside. Usually below 10 degrees.
    FatBoy85 likes this.
  15. FatBoy85
    FatBoy85
    Washington State
    Oh I didn’t think about that. Since it hardly drops anywhere near that and only up in the mountains and Eastern WA . Never cut in that kinda cold.
  16. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Not well, hydraulic oil is very light.
    I’m lucky at my work we use a special preservation oil before we ship our gearboxes, and it has a tackifier additive. Very similar to bar oil and free! My former boss cuts a lot of wood and has several 55gal barrels worth.
  17. jrider
    jrider
    Used up the last few drops of that expensive bar oil and am not back to using the cheap County Line oil.
    dgeesaman, Farmchuck and buZZsaw BRAD like this.
  18. The Wood Wolverine
    Honestly, I’d prefer the Husky (sorry, no experience with the Stihl) oil. It has more tackiness than the TSC, but there’s no way it’s worth the price difference. I find the Itasca and the TSC do the job just fine. As long as there’s a tackifier it in, I’ll run it.
    dgeesaman and jrider like this.
