Bar and Chain Oil
Discussion in 'Chainsaws and Power Equipment' started by NYCountry, Nov 6, 2018.
  1. Horkn
    Same here. I'll buy whatever is the best deal usually that's menard, but fleet farm has good deals too. There's really not a lot to bar oil. It's not like it's 2 stroke engine oil.
  2. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I use the Menards oil also. In the last few years I have went through at least 20 gallons and no failures yet.I have a Forester bar on an 026 that has at least 50 cord on it and I have not dressed the rails yet.
    HoneyFuzz, mike bayerl, Horkn and 4 others like this.
  3. Barcroftb
    Barcroftb
    The Mitten
    Just a heads up I think bar and chain oil is on sale through November 11th at Blaines farm and fleet for 4 bucks a gallon. I also use the FVP from Menards gooder stuff.
    HoneyFuzz, RCBS, Fanatical1 and 6 others like this.
  4. The Wood Wolverine
    Tractor Supply oil here too. Usually about $6/gallon when on sale. I'm really not picky as long as it is dedicated bar oil. I won a bunch of the Itasca at a gtg and it worked perfectly fine. Used Husky but it's too expensive.
  5. trail twister
    trail twister
    I normally watch for the switch from summer to winter oil at TSC and get the summer stuff for about 5 bucks a gallon. Never gets all that cold in my part of michigan when a winter blend is needed I feel.
    Last stuff I got was Super tec for 4.00 a gallon at Wally World about 2 weeks ago.
    :D Al
    HoneyFuzz, mike bayerl, Horkn and 3 others like this.
  6. Firewood Bandit
    Firewood Bandit
    I won't cheap out on bar oil, but won't spend stupid money either. I really like the old green jug Poulon, Essence or Service Pro.
    HoneyFuzz, RCBS, mike bayerl and 2 others like this.
  7. papadave
    Menard's has BC oil for $4.99 until the 10th.
    HoneyFuzz, mike bayerl, Horkn and 5 others like this.
  8. papadave
    I don't consider not wasting money as "cheaping out". To each their own.
    I don't cut a bazillion cord every year, so for me, less expensive works just fine.
  9. saskwoodburner
    saskwoodburner
    I'm the opposite of Firewood Bandit, I cheap out out on bar oil! I blend with filtered/strained cooking oil and it works fine. It costs around $4/liter or $15 for a 4 liter jug of bar oil, so it's actually the biggest expense for cutting. Every time I burn up $5 gas, I'd burn up $15 in bar oil, so even mixed half and half the savings shine through.
    Horkn, amateur cutter and Barcroftb like this.
  10. Firewood Bandit
    Firewood Bandit
    If I can get "premium" bar oil for $6-7/ gallon, it is not exactly like I am paying "Stihl" prices. :p:whistle::picard:
    On the Service Pro, I split an order of 8 cases, (6 gallon case) with a friend at $7 gallon. It is probably the best bar oil I have ever seen. Stringy like snot.
    HoneyFuzz, RCBS, mike bayerl and 3 others like this.
  11. chbryson
    chbryson
    I stocked up with about 10 gallons of TSC oil the last time it was about $5/ gal. Have about 4-5 gallons at the house and 4-5 at camp so i am good wherever there is a saw.
    I'm surprised no one has brought up used motor oil. We haven't seen that argument for a while. :deadhorse:
  12. trail twister
    trail twister
    That is pretty much why it isn't brought up, who wants to argue with the antis.
    :D Al
  13. brenndatomu
    Yup, this...and sometimes it is on sale with a 11% rebate too...$4.49! [​IMG]
    This is what they have right now...sometimes its the Cam 2 stuff...that seems fine too.
    HoneyFuzz, RCBS, Screwloose and 9 others like this.
  14. Farmchuck
    Farmchuck
    Nepa
    Itasca $8.49 gallon @ Matthews Hardware.
  15. mike bayerl
    mike bayerl
    If I may be so bold, it looks like the sum of our cumulative experience is: "Any dedicated bar and chain oil will do, look out for local sales and then stock up." Just don't use "alternative " oils such as used motor oil, vegetable/salad oils etc.
  16. papadave
    My SisIL asked a couple days ago if it was ok to use regular motor oil, and I told her about the tackiness of B&C oil.
    Screwloose and Fifelaker like this.
  17. saskwoodburner
    saskwoodburner
    Have you had a bad experience using canola oil which makes you draw this conclusion? Any proof to persuade me it doesn't work well, when it does?
    Windy Isle, Screwloose and papadave like this.
  18. papadave
    I've used Canola oil too. Worked fine.
  19. brenndatomu
    Heck, spit would probably work if ya had enough of it...:rofl: :lol:
    I think the main thing is to keep friction and heat down...and about any oil should accomplish this.
    That said...I'll keep spending my annual average of ~$5 for bar oil to cut my firewood for the year...:D
    HoneyFuzz, RCBS, Screwloose and 5 others like this.
  20. The Wood Wolverine
    I roached a bar using a non specific oil. It will fling right off the tip and not properly lubricate the other side of the bar if it has no tackifier.
    I can send the bar as proof... 37” Windsor Speed Tip. I was milling and couldn’t see or “feel” it get too hot till it was too late (early on in my experiences with the csm). Figured the oiler on the 394 would put out plenty, which I’m sure it did as they oil like a hoss. Just that without that additive, centrifugal force did its job.
    RCBS, Screwloose and brenndatomu like this.
