"Backyard Blacksmithing" pounding iron on the forge this evening!
Discussion in 'Hobbies and Interests' started by blacksmith, Dec 18, 2016.
  1. blacksmith
    blacksmith
    central Pa
    Practice? I think that you did pretty darn good! You should be proud of that!:dex::thumbs: If for some reason that you decide to hang it up at some point for a decoration wire wheel it, get it pretty warm then coat it with beeswax while it's still hot and wipe it offthe excess. This way it will retain the original look without rusting. :thumbs:
    Chaz, brenndatomu, metalcuttr and 2 others like this.
  2. Warner
    Warner
    Excellent thanks for the encouragement. I don’t think it will be a wall hanger. I will keep the bees wax info in my hat for future projects!
    Chaz, blacksmith, metalcuttr and 2 others like this.
  3. J. Dirt
    J. Dirt
    Yeah!!!!! I’ll second that looks pretty good! Especially squaring an entire piece of round stock! Like blacksmith says get some beeswax on her, just don’t get it to hot while applying. Don’t ask how I know :whistle:
    Chaz, blacksmith and metalcuttr like this.
  4. Warner
    Warner
    Thanks
    Chaz, blacksmith and J. Dirt like this.
  5. Midwinter
    Anyone know what's going on here?
  6. Chaz
    Chaz
    Southwestern NY
    Just your local smith making some plates.
    :whistle:
  7. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Brushing the scale off the piece.
  8. blacksmith
    blacksmith
    central Pa
    I've seen that video before. As J. Dirt has said they are brushing the scale off of the steel. I believe the were making some type of a ring to make a gear.
  9. J. Dirt
    J. Dirt
    Fixed it for you .... :handshake:
  10. blacksmith
    blacksmith
    central Pa
    Hahaha!:rofl: :lol: How'd I do that I don't know what I was thinking. :hair: For some reason I thought that you posted that. Sorry fishingpol :whistle:
  11. blacksmith
    blacksmith
    central Pa
    Here's a pretty cool video that I came across! :hair:
    Chaz, Marvin and J. Dirt like this.
  12. TurboDiesel
    Drop forging?
  13. Chaz
    Chaz
    Southwestern NY
  14. Warner
    Warner
  15. Warner
    Warner
    E805F4D1-B68C-4BCE-99AB-0F50E1F7B3C9.png I just tried the link I don’t think it’s going to work
  16. J. Dirt
    J. Dirt
    I couldn’t get it to work either. That’s ok the picture works and I searched it on eBay.
    I’d just wonder if you could make your own cheaper? Either way you just want to take into consideration what you might plan on making. Being that that’s set up for knife making long narrow projects are great in it like twists in long stock, but you might kick yourself if you get into something bigger like bending loops or rings with closed ends or big strap hinges.
    Truthfully though it’d be a great place to start and you might find it works great for everything you do. I would also check to see what the propane burn rate is. If you can get away with a 20 pound tank for a few hours work or if you need to pipe into the 500 gallon house tank. I’m sure some of the other guys have more input. That’s just my thoughts. :D
    P.s I’d like to own one to run next to my little coal forge!:thumbs:
  17. Warner
    Warner
    I think I’d run it on 100 lb tanks. They can legally be transported and filled. Coal is around here but not readily acessable
  18. J. Dirt
    J. Dirt
    Coal here was a 3 hour round trip for me. :picard:
    blacksmith, TurboDiesel and Chaz like this.
  19. Warner
    Warner
    I’m quickly realizing this may be an expensive hobby...
  20. J. Dirt
    J. Dirt
    The anvil is the biggest purchase followed by the forge. Mainly after that it’s all material cost or scrounging. It’s kind of like firewood!
