"Backyard Blacksmithing" pounding iron on the forge this evening!
Discussion in 'Hobbies and Interests' started by blacksmith, Dec 18, 2016.
  1. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    metalcuttr, you have some real nice work. Feel free to add projects. This thread has evolved to metalworking in general.
    As far as forming the pig, I used a wood cutout with rounded edges. I just used different weight hammers on a soft pine board to hammer out the different depths of the pig. I used from a 2 ounce up to a two pound hammer.
    I've looked at sand and shot bags and will eventually get one if I get more work for copper. I'm limited on space, and a copper work is a small percentage of what I do.
    I have a friend with a large oak dishing stump with about five different sized divots. He uses it for bronze sculpture. It is really nice to use. So many surfaces to work and they are almost smooth as glass inside. I believe he has bands around it too. I made a small one, but it moved too much.
  2. metalcuttr
    metalcuttr
    western WA
    Thanks for the info. It appears you use the soft board much the same as I use the log round. Interesting about the oak stump. I can see how a much harder wood with preformed hollows and shapes could be used to form softer/thinner metals. The metal would deform before the hard wood!
  3. fishingpol
    fishingpol
    I do anneal the copper for more flexibility...
  4. J. Dirt
    J. Dirt
    Where do you get your copper fishingpol ? I thought about picking up some, but online it’s pretty expensive!!!
  5. fishingpol
    fishingpol
    Local sheet metal supplier sells to the public. I ask for the cut off pieces from larger sheets. Not too expensive. We are fortunate to have them.
  6. metalcuttr
    metalcuttr
    western WA
    It is funny how local prices for metal of all types seem to be more reasonable back east. Here in WA St. the local prices are much higher unless buying in large quantities. One would think with the availability of cheap Chinese and Korean steel, the prices would be more reasonable. Around here even the rems are the same price per pound as the full sheets. Of course, recently, the whole overseas tariff thing has really scrambled metal prices!
    raybonz, brenndatomu, J. Dirt and 5 others like this.
  7. blacksmith
    blacksmith
    central Pa
    metalcuttr that work that you do with the fish are absolutely beautiful! I don't think that I could do that ,it looks very difficult.
  8. J. Dirt
    J. Dirt
    X2!
  9. NortheastAl
    NortheastAl
    Putnam County NY
    X3
  10. raybonz
    raybonz Moderator
    Carver, Mass.
    Beautiful work! The pinecone looks real!
  11. J. Dirt
    J. Dirt
    For a while I’ve been wanting to make a campfire tripod to hold a kettle or a pot with a handle. This was the project I had in mind a few months back when I wanted to get into smithing. Just finished it, hope to put it to use later.....
    Excuse the garage disaster :picard:
    One of these, torch welded to close CBD14312-BFB5-4973-B803-5D821E8E235E.jpeg
    Hanger hook with a brazed on lift ring 130F47BA-87D3-4D0D-A221-4897FDF8D9BF.jpeg 4EFD3F92-2FE9-43E1-AB5C-474E56C3B942.jpeg
    Flat strap hanger with hot punched holes for the adjustable hook. I think they call it a trammel hook? 4991DE8F-0DA3-452D-904A-A82709ADCADF.jpeg
  12. J. Dirt
    J. Dirt
    Here’s the assembly.
    Made a ring to go inside the eye pole, torch welded closed. 8C10166C-BCDA-4A07-8BC0-E4F81FF7C001.jpeg
    The hook and slide together. The hook is removable through the bottom hole. 0511FD06-F9A0-4487-B6FF-0204EFDFDD57.jpeg
    Whole shootin’ match! Don’t worry I’m not making dinner in the galvanized bucket 5C936147-A5F3-41ED-910B-60B8D8655369.jpeg
  13. J. Dirt
    J. Dirt
    All in all it turned out well! :cool:If I were to make another I would use square stock for the legs and I think square stock for the hook slide and just hammer in flats where I want to punch the holes. I think it would look much nicer.:thumbs: By the way I made another leaf from 3/8” round stock:loco: :crazy::picard: DD610BA7-2C17-4D47-B2EE-4D1EEFC19525.jpeg
  14. fishingpol
    fishingpol
    This is just a small project for jrcurto . It's an extended damper handle made from 1/4" steel rod. The maple leaf was cut and filed from steel sheet. The handle he had was short, and this one should keep it further away from the stove top.
    Finished with beeswax
  15. J. Dirt
    J. Dirt
    Nice work!, as always !
  16. Chaz
    Chaz
    Southwestern NY
    Saw this the yesterday..
    I think :santa: got some of you guys figured out.
  17. metalcuttr
    metalcuttr
    western WA
    Really like your tri-pod and trammel! Would be great for out door fire pit or camping. Next spare moment I might try my hand at one. Thanks for the idea!
    blacksmith, brenndatomu, Chaz and 2 others like this.
  18. J. Dirt
    J. Dirt
    He’s on to us!!!! :rofl: :lol:
  19. J. Dirt
    J. Dirt
    I actually was working on another one for a co worker today. Im going to try and work on it more tomorrow if I get time. This time out of 1/2” square.
  20. J. Dirt
    J. Dirt
    Working on a twisted ring for the tripod yesterday. C998F61B-D040-483A-91E5-C99FD40D1DBF.jpeg A0528930-083A-4F21-BF52-2B1550E63770.jpeg
