"Backyard Blacksmithing" pounding iron on the forge this evening!
Discussion in 'Hobbies and Interests' started by blacksmith, Dec 18, 2016.
  1. HolsatiaRedneck
    HolsatiaRedneck
    Schleswig-Holstein
    Well nice!
    blacksmith and J. Dirt like this.
  2. J. Dirt
    J. Dirt
    2B9158D2-5CD7-4A84-9633-850A64C4571C.jpeg Made from a 4’ piece of 3/8” rod with the acetylene torch. Put it right to use last night and again today!
    Next up.... my attempt at making a coal forge!:dremel::heidi:
  3. J. Dirt
    J. Dirt
    Bare with me! :picard:I’ve always been interested in blacksmithing and I’ve gotten in to outdoor cooking a bit more and was looking at buying some campfire tools. Well why buy when you can make them?! So that’s mainly how this build started. After some reading and discussing things with the real blacksmith I acquired some parts. CA4B287C-B473-436B-9F45-5D93D5B66ADF.jpeg 3D169B66-25E9-4C23-99EB-1E967BC9EF73.jpeg Then set to work.....
    Using a brake drum as a Firepot I ended up drawing out a bottom plate to bolt into the drum and weld my pipe to. 05E84376-485E-4C83-A78D-12A1B231782D.jpeg
    I’ve not got the steadiest hands but the acetylene blew it out pretty well FA79FA31-6468-46C2-B566-E8A21B21B26E.jpeg
  4. J. Dirt
    J. Dirt
    I had some heavy sheet metal shelve pieces to form a table then used 3/4” gas pipe to make up a frame 01EFCEC5-C962-4FF0-B825-0809CA3529C7.jpeg Added some wheels and doubled up the sheet metal table BB4A89C7-D1DB-4969-857E-B4B7B377076B.jpeg The big flip! I also drilled a bunch of holes through one layer of the steel and plug welded through to tack the pieces together. 1F34D5BD-EEEA-426F-AF72-D4CDC71A5B46.jpeg
    Marked and blew the hole for the Firepot 7EAA4247-DC12-4CDA-B7E9-D22411C79C63.jpeg
  5. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Good start so far. I have a similar set up using a truck drum and can post pics if needed. Just watch the depth of the firebowl. You need a decent mound of coal for a good fire, but if you are heating a piece of long stock in the middle, the bowl should not be so high the work it at the top of the mound.
    You'll find ways to modify it to make working comfortable.
    I used 1/4" round stock for my tuyere, and with the airflow blowing upwards, it is good condition.
    blacksmith, NortheastAl and J. Dirt like this.
  6. J. Dirt
    J. Dirt
    Pretty good fit after a little grinder cleanup
    Mounted up the pipe and bottom flange and bent up some steel straps and welded on some bolts to tighten the straps to the frame. 74DDC39A-3977-4530-8F83-6D3A816E8B55.jpeg
    I got half dozen rain flaps of all sizes kicking around, finally put one to good use made a nice ash dump. 6A1631B1-C0D1-4B12-998C-0CEDB07B1BEF.jpeg Looks nice from above. Added a tool hanger/handle for easy moving. 5B934769-AB72-49CD-8D39-737F5713BFE7.jpeg
    blacksmith and NortheastAl like this.
  7. J. Dirt
    J. Dirt
    The next step was laying down some clay. Of course I couldn’t find any locally so why not grab some out of a fill pile at my parents house!
    Sifted it out and watered and mixed it in the wheelbarrow. Seemed to lay in pretty nice along with a few fire brick.
    Gave it a few days then couldn’t wait so I fired it up with some lump charcoal and my makeshift air source :loco: :crazy: 7319F612-9623-44CB-A45C-5812055CEDBB.jpeg
    Using my baby anvil that was my great grandpas that he must have used to set mower section rivets on. 9DA7331B-1119-41CA-B03C-7103F2D12692.jpeg I hammered a fire tool out of an old piece of rebar I found in the barn. 4D1883DE-74F4-4516-8C45-DA75C3646D2F.jpeg
    After all the fun I cleaned it out and noticed all the cracks in the clay. 5561B8C1-8698-486B-BC1C-3E802C1C04BF.jpeg
  8. J. Dirt
    J. Dirt
    I was then in the hunt for a blower. Of course my dad had an old electric exhaust blower from a hot water tank. So I just stuck it on to test it out. I also found some fancy stuff in a tube and used it to fill the cracks in the meantime to see how it goes. 74195897-6D7F-4BF6-947C-859E5D7B30B2.jpeg
    Yesterday after a bunch of calls and asking around with people looking at me like I had six eyes, I finally found coal!! A three hour round trip and five hundred pounds on the truck I got some! Haven’t yet wired up or permanently mounted the blower, but I could resist to fire it up and sniff some coal soot!!:dex: 73DA23AA-7B70-4854-84AB-FD128A8EFAEF.jpeg
  9. J. Dirt
    J. Dirt
    All that’s left to do is get an anvil, which is proving to be either very expensive or next to impossible to get a used one. I can’t wait to get everything together and start learning though!!! The first project is going to be an adjustable height campfire tripod for hanging a kettle or Dutch oven. Then I saw some cool table utensils the other day to try marking. The possibilities are endless. Oh did I mention not only trying to find an anvil is next to impossible so is finding the time to do any of this!! :rofl: :lol:
  10. billb3
    Target for a canon ?
  11. J. Dirt
    J. Dirt
    Discus catcher!
    NortheastAl likes this.
  12. J. Dirt
    J. Dirt
    B1BE03FC-B444-48B3-9EE6-922501E5798C.jpeg First little bit of :fart:around today had a piece of 5/8 round stock kicking around so I tapped this out. Fffaaarrrrrr from straight!!!
    What’s a good thing to use to seal it from rusting? Especially if I plan to use it!
  13. Scotty Overkill
    Looks good buddy! I simply wipe all my wrought steel utensils down with veggie or olive oil after each use.....
  14. Scotty Overkill
    Did you see the mess kit spoon and knife I made last winter? Both made from an early 19th century spatula handle, the spatula was junk, so I repurposed the handle inot these...
    fishingpol, blacksmith, Chaz and 2 others like this.
  15. J. Dirt
    J. Dirt
    I think I saw them reading through the thread at some point. Nice work as always!!! Definitely cool to be able to use and repurpose old iron!:thumbs:
    blacksmith, Chaz and NortheastAl like this.
  16. J. Dirt
    J. Dirt
    Thought you guys might like this. There’s a local history museum/village near us and we went today to wander around a bit. It’s a recreation of a local circa 1899 shop that was in the area. Of course I took some:ithappened:wish I had stood back and took one from outside. 63CCA6AB-3596-4235-A4E8-98F2901365CD.jpeg 12A201ED-B0E3-4ECE-B5EA-3B84A6A0A938.jpeg D6B23D54-C014-4314-9B6A-BFAF0D2B7D12.jpeg E1FC7901-5DB4-45B0-A2EA-921F9978738D.jpeg 91ECB6C8-B35A-4A05-95C2-0F62975946E4.jpeg 3789DBDE-EFB5-4541-A19D-FA7F2A85B154.jpeg 5BA5620B-A205-4FE3-8F27-0F5EAB10B6CF.jpeg
  17. J. Dirt
    J. Dirt
    On the subject of aprons...
    Where could I get a side of full grain leather to make my own?
    OR
    Where can I find a decent apron that’s not outrageously priced?
  18. Midwinter
    There's an anvil up for auction ( online auction) the next town over from me.
    Showing 1 to 1 of 1 lots
    104 - Antique Anvil With Numbering on Front
    1 Image(s)
    3d 3h 7m
    High Bid
    87.50 USD
    All items sold as-is where-is and are sold untested. No shipping available. 10% Buyers Premium on all items.
  19. J. Dirt
    J. Dirt
    It will be interesting to see what that goes for. :binoculars:Around here that’s $500 plus all day!!
  20. Midwinter
    I'm registered, want to put in a bid?
