Back issues again
Discussion in 'Everything Else (off topic)' started by Unicorn1, Sep 12, 2017.
  1. wildwest
    I had one for prelabor, not sure how much it helped but it did give me a distraction.
  2. Backwoods Savage
    Actually I had 2 of them and donated both to the hospital.
  3. clay shooter
    clay shooter
    ENGLAND
    my wife has had tens machines over the years,they do help for a while but dont last a life time.
    Backwoods Savage and savemoney like this.
  4. HDRock
    Any more info you can provide is appreciated.
    savemoney likes this.
  5. clay shooter
    clay shooter
    ENGLAND
    i am so lucky i dont get them at all.with all the work i do lifting heavy stuff about,
  6. Flamestead
    Flamestead
    Windsor County, VT
    I damaged L5/S1 doing firewood in spring of 2016. Pain got to where I couldn't even do the desk job. Over a month of pain while wending my way through the medical community before discectomy. That stopped the pain right off. Have had numbness in my feet and one leg most of the time since then, but noticed recently it is nearly gone. Still some numbness when I do too much, but then it fades.
    I can do about 70 to 80% of what I used to be able to (have a small farm, still do a lot). Two guys at work tried the manage the pain route in part because they were scared of the surgery. I've been very happy with my outcome, especially compared to theirs.
    HDRock and savemoney like this.
  7. wildwest
    Hi guys, something is ruining my sleep more and more over the last few years. You know where your "hip bones" stick out in front (thinking its actually pelvis)? Would that be the iliac crest?
    Anyway the pain that is stealing my sleep is both on the inside of where you can feel those "hip bones" and also a bit lower on the outsides, which I assume is my actual leg bone where it comes out of the hip joint.
    Looking for some stretches/excersises on the internet but there is too much info out there and guess I need the correct terminology to google for it. Any help appreciated:)
    PS, better posture is one my New Year's Resolutions, so I'm hoping that catches up and helps at some point (sadly I've been slumping for longer than I realized now).
    Backwoods Savage and Stinny like this.
  8. justdraftn
    justdraftn
    On the road
    Piriformis syndrome.
    Yoga pigeon pose stretch.
    Midwinter, brenndatomu and wildwest like this.
  9. Stinny
    What we all need H, is a gravity switch, so it can be turned off from time to time. Somebody whip that up, wouldja... ;)
  10. Midwinter
    Backwoods Savage, wildwest and Stinny like this.
  11. Backwoods Savage
    As you can tell by the picture, the iliac crest is in back, not in front. From what you describe, you may be facing a hip surgery soon.
    NH mountain man and wildwest like this.
  12. blacktail
    blacktail
    PNW
    It's called an inversion table.
  13. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Blacktail beat me to it. My son in law fell out of a tree stand. Compressed some vertebrae, 2-3 years with an inversion table and he swears it helped more than anything else.
  14. brenndatomu
    I tried one for a while...couldn't take the blood rushing to my head...even just easing into it, not going too long or down too far. Sent it back from whence it came...
  15. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    He took a while (I don't know how long) before he hung straight up and down. Then he still only followed the recommendations. He still uses it occasionally now when he feels a tinge in his back.
  16. wildwest
    I found one of those, less than $100 at Walmart about a year ago. WWW says its awesome temporary relief that he appreciates and he uses it atleast once per week (he was told sciatiaca). Me, well similar to you, except blood to hands hands is painful and the blood to head not comfy either, and need him to twist my pelvis anyway--easier to do on the floor (my mother had a terrible back and all of us were trained on how to adjust it at home for her).
    That said there is a strap in the one I bought to control the angle which I should probably experiment with more.
  17. Stinny
    You might also try "hanging" right side up with some type of supports under your armpits, similar to the top pads on crutches. Just a thought...
  18. Backwoods Savage
  19. Greenstick
    Greenstick
    Try looking up hip pointer injuries. Not sure if this is exactly the same but don't hurt to look.
  20. wildwest
    Thanks Greenstick, god knows I always need common sense suggestions :) And yes, I may have done that once or twice or a couple dozen times (exact height for kitchen table corners :picard: as well as an outdoor pool I worked at for many summers with a water slide . FUN stuff using the water slide after hours but yikes I discovered the seams between the tube segments were not level while even going down on stomach as going down on the kick board mats...... but it was just too fast and fun to use the boards)
