ATV winch cable
Discussion in 'Chainsaws and Power Equipment' started by Beetle-Kill, Jun 4, 2015.
  1. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Re-spooled my Warn 2K with 3/16- 7/19 galvy cable last weekend. I can't find anyone with a swager for the ferrule to save my life.
    So... would you trust cable clamps to hold the line?
    Thanks, JB
    Well Seasoned and Stinny like this.
  2. FarmHand78
    FarmHand78
    South East Iowa
    I wouldn't, I've seen to many cable braces slip to trust cable clamps. I've also seen atv winch cables snap, scary stuff!
    Beetle-Kill and Horkn like this.
  3. bogydave
    Evanrude, Horkn, FarmHand78 and 2 others like this.
  4. Stinny
    Wish I lived closer BK. Have both the tool and a few 3/16" swags. Cable clamps will work as long as you've got a couple of em and they're installed the right way.
  5. bogydave
    +1
    never saddle a dead horse !
    Put the saddle on the live side of the cable & the U on the dead end side. :D
  6. Beetle-Kill
    Beetle-Kill
    Gonna make some chokers and extension cables also. I've got about 500 ft. to play with. It's rated for #4300, so 2K load should be OK.
    If clamps will work, I'm a happy camper.
    My first ATV winch, gotta ask so I don't mess up. Thanks guy's. JB
    Horkn and Stinny like this.
  7. redneckdan
    redneckdan
    Northern Minnesota
    Make a Flemish eye then wrap the tag and main line with electrical tape, then apply your cable clip.
    Personally, I taper the tag, wrap with electrical tape, then wrap with mechanics wire. I have NEVER had a splice blow with this method. Field eye spliced two 3/4" cables at the mine last week that the cat skinners proceeded to blow up trying to yank a 789 out with two D9s.
    I make my chokers this way also.
  8. lukem
    I used 2 aluminium cable crimp sleeves and pounded them tight with a hammer on a concrete floor. Held up to heavy abuse for several years now.
    concretegrazer, Horkn and Beetle-Kill like this.
  9. Beetle-Kill
    Beetle-Kill
    One of my guys at work knows how to do a Flemish eye. Old school mine-worker, said the tag is the critical part. I'll give it a try. Thanks, JB
    Horkn likes this.
  10. Horkn
    This thread reminds me that my parents mucked up the winch cable on the sportsman 500.
    I should just buy that synthetic rope for it and be prepared to change it out when I get up north next time. Probably over the 4th of July.
    Beetle-Kill likes this.
  11. Beetle-Kill
    Beetle-Kill
    If our parents never made mistakes, most of us wouldn't be here.
    Things to ponder..... ;)
  12. Horkn
    My parents wanted a girl. They tried 3 times, all boys. Then they gave up.
    I don't blame them.:rofl: :lol:
  13. Beetle-Kill
    Beetle-Kill
    Ok, finally made the time tonight to do the winch line.
    7 x 19 - 3/16 wire rope
    Did the Flemish eye, then slid the clamps to tighten the thimble. 3 clamps @ 18/16 spacing, tag is 1/2" behind the last clamp.
    Am I good? Getting ready to re-spool under load to cinch everything up.
    Stinny likes this.
  14. Stinny
    3 clamps should more than do it. Cinch'r up... :yes:
  15. Beetle-Kill
    Beetle-Kill
    Cool. For the chokers, can I get away with 1 or 2 clamps if I eliminate the thimble? I'd be surprised if I had more than 750-1000lbs. to drag, max.
    Stinny likes this.
  16. Stinny
    IMO... I'd like 3 on the chokers just because they can get some abuse as they grab logs and then roll over while dragging. It's always hard on the cable without thimbles but can't really use a short cable as a choker with thimbles... usually can't get an end thru the thimble. Could use nylon slings as chokers. I use 1" slings a lot.
  17. Beetle-Kill
    Beetle-Kill
    Nylon slings are a good call, will start sourcing them. Or I'll spring for some 3/8 chokers, only need 2 at this point.
    Thanks, JB
  18. redneckdan
    redneckdan
    Northern Minnesota
    I would pass on the clips and thimble. Tape and wire wrap would be your best bet. I ran on last winter on the same choker.
