ATV Battery
Discussion in 'Chainsaws and Power Equipment' started by lukem, Jan 21, 2021.
  1. lukem
    I thought below 10 was trouble too.
    Screwloose likes this.
  2. Lastmohecken
    Lastmohecken
    Arkansas
    They are getting more expensive, all of the time. I have a 1995 Yamaha 400 Kodiac 4-wheeler which I bought new, and have always just gone to Wal Mart and bought the best battery I could find for it. I think I have probably only bought 3 or maybe 4 batteries for it in it's life time. That would be about 5 years per battery, and the thing set parked outside on the porch for most of it's life and would set for days, even weeks at a time, except in the winter when I had to use it more often, usually 3 to 4 days a week, feeding cattle. 5 years is about all I get out of any battery for anything.
    Horkn, Screwloose and brenndatomu like this.
  3. brenndatomu
    That battery might go a little longer, but sounds like its close to the end of its life. Honestly I'd probably replace it sooner than later...cranking with low voltage can cause starter solenoid contacts to weld together, and can cause problems with electronics too...
  4. Lastmohecken
    Lastmohecken
    Arkansas
    Yep, I would take it out, and take it to Wal Mart or O'Reilly's along with my tape measure and look for a battery of same size, and same terminals, with the highest cold cranking amps I could find, and go with it. And check the battery box/holder to see what the max size battery I could shoehorn in there, if you didn't already have the biggest battery that would fit, already. When I buy a battery for anything I want the highest cold cranking amps available, because I want to be able to drive to town the starter if I need to. Just kidding, but you get the point. :)
    Horkn and Screwloose like this.
  5. lukem
    Yup....
  6. thewoodlands
    thewoodlands
    I tested our battery which ended up bad, it tested about 12.5 but under load the needle went to bad. They tested it at Advance Auto and they came up with a bad cell.
    The Wood Wolverine and Horkn like this.
  7. clay shooter
    clay shooter
    ENGLAND
    the battery i have seems ok, but can never get it to crank up fast.may be i need a better battery.
    Horkn likes this.
  8. Ikeholt
    Ikeholt
    indiana
    Not something that would work for everybody, but I use a lawn mower battery rigged up on a back tool box. Hate those expensive ATV batteries, lawn mower batteries are less than 30 bucks and I get about 5 years out of them. Also has more power for the snow plow.
  9. Horkn
    True, but even at idle it needs to be above 12v.
    clay shooter and brenndatomu like this.
  10. Horkn
    There's really not much of any"extra" room for a bigger battery on ATVs. Obviously you buy the battery with the highest CCA.
    clay shooter likes this.
  11. The Wood Wolverine
  12. lukem
    New battery (Yuasa YTX14) battery arrived yesterday. Filled it with electrolyte and let it trickle charge overnight. Swapped it in early this AM. Cranks over so much better, lights are brighter, etc. Didn't realize how bad it was.
    Ronaldo, Horkn, clay shooter and 2 others like this.
