asthma
Discussion in 'Everything Else (off topic)' started by nate, Jul 4, 2014.
  1. Stinny
    Are different states better than others when it comes to getting VA services? Have heard Maine vets say things here are pretty good.
  2. JustWood
    JustWood Guest
    I have allergies and asthma . You can try different over the counter allergy meds. I have found the Claritin 12 hour works best for me. The Zyrtec also.
    The 24 hour meds don't work as well but will take them after a 2 or 3 day run of 12 hour meds. The 12 hour meds tend to make me dizzy after 3+ straight days of taking them.
    My doc told me to pop a med as soon as I noticed the slightest little symptom and it's worked well for me. Used to get really sick from allergy/sinus drainage. Now if I catch it early, no problems. First symptoms are usually itchy ears/eyes. The hard breathing usually occurs if I don't catch it in time. Don't have to use an inhaler yet. Doc told me eventually I will.
    Stinny likes this.
  3. savemoney
    Have you called your VA Rep yet? Have you written to your congressman and senators? I want to tell you, I retired from the VA. They Don't want anymore heartburn. The squeaky wheel is the one that gets greased. You need a pulmonary assessment. Not a cop out. Write down everything you went through and then present it. You need to make the move. A bad experience with an MD visit should not put you in defeat.
