AS Reburn puffing?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Marshel54, Mar 25, 2020.
  1. Marshel54
    Marshel54
    My AS has some fairly violent puffings from the reburn igniting. After the puff reburn goes out until the next time gasses build up. Which way to move the incoming air?
    I have given it more air and had a nice established reburn. I have also reduced the intake and got the same results. What is the key? Does not appear to be any rhyme nor reason.
    Camber and Chaz like this.
  2. Nitrodave
    Nitrodave
    Grayling Mi.
    In fire service terms... you are experiencing “Backdraft” ... (Remember the movie ?)
    a backdraft occurs when there is a high heat, high fuel gas (smoke), but lacks oxygen, then gets a proper amount of oxygen... then POOF !!
    It’s happening in our stoves, because they close down so much. The smoke builds up, chimney cools and firebox goes rich. It then cools off enough that There is less fuel gas and it leans out .... poof !! Then the cycle continues. So you either need to cool the coal bed... shut air down ... or the quicker way is to open the rear air and let it flush some of the fuel through. Don’t open the door when the box is black... you will have a bunch of smoke in the house !! I have found that this only happens about an hour after a good reload. Just try to keep a small lazy flame, then it won’t happen.
    Camber, Chaz and Marshel54 like this.
  3. BDF
    BDF
    Often opening the draft slightly will cure back- puffing. Sometimes, closing it will also. The problem is that there are so many variables, no one can say anything so simple as close the draft 10% and all will be well.
    The cause, as you already pointed out, is the collection of flammable gasses and introducing just enough oxygen (from the air) to ignite those gasses. The 'cure' is to prevent either the flammable gasses from collecting so much, reducing the available oxygen in the firebox or both. Back puffing is often a problem with very dry wood such as kiln dried lumber. Being pine, it also off- gasses at a very high rate as compared with hardwoods. Another problem is getting the entire firebox full of wood up to temperature so that it pyrolyses (smokes) and then shutting the draft way down for the long burn. Instead, try starting off with a much smaller amount of wood, get it well- engaged, then load the stove and shut the draft down without allowing the entire load of fresh fuel to get hot enough to generate smoke. Thing of it like the way a cigarette burns: from one end and it just smolders. But if the entire cigarette is ignited, it will make a huge amount of smoke all at once.
    Finally, mixing in a little [less dry] wood can help immensely. We all strive to burn dry wood, and we should but extremely dry wood can also be problematic.
    Brian
    Camber, RGrant, Fanatical1 and 3 others like this.
  4. TurboDiesel
    More often than not, i open the draft and get a little more flame to stop the backpuffing.
    It usually doesn't backpuff unless it's a little warmer outside and or rainy
    Marshel54 likes this.
  5. Marshel54
    Marshel54
    Exactly what I was thinking, but the other night reducing air solved the problem.
    Exactly what I am experiencing.
    Was definitely not to dry of wood. I was burning black locus that was css last winter. Most of the time the firebox is full when I experience it the most. When I can get it throttle down with a lazy dancing reburn it put out a tremendous amount of heat.
    How is Phoebe doing?
    The last couple of times it has been fairly warm and rainy. I often times delay bedtime until I am comfortable not having backpuffing.
  6. Nitrodave
    Nitrodave
    Grayling Mi.
    that’s because reducing the air , cools the fire, which in turn produces less fuel gasses.. which leans the firebox and no more poofing.
  7. brenndatomu
    This ^ ^ ^ just the way the Kuuma furnace burns too...starts in the front and keeps the front of the splits burning juuust enough to off gas...but since you guys have a cat, the AS can burn lower and slower than the non cat Kuuma can.
    Loading on some hot coals at the front makes the whole process work better too...not sure if that would apply to the AS or not?
    Maina and Fanatical1 like this.
  8. Nitrodave
    Nitrodave
    Grayling Mi.
    One possible drawback to the AS, it side loads, so it East west... but the air curtain come down the front glass and hits the side of the splits... hard to get that end burn type fire..
    brenndatomu likes this.
  9. BDF
    BDF
    OFF TOPIC:
    Phoebe is doing great! A big cat in the first place, she is also pretty fat- I call her 'Jabba the cat'. But she seems perfectly content, is a great pet and is actually getting quite affectionate, more than two years since she 'moved in'. :)
    Brian
  10. Woody Stover
    Woody Stover
    Southern IN
    OK. I was also gonna ask how your draft was. A short chimney would also be more prone to smoke buildup in warm conditions.
    I like BDF's idea of getting the stove up to temp on a few splits, then loading and shutting down the air before you have a lot of wood gassing. You gotta have dry wood for the rest of the load to eventually burn, though..one-year BL might not be dry enough.
  11. clemsonfor
    My stove does it this time of year. When its not really cold outside and I try to keep a low slow fire. I usually just either open my bypass damper a little or open the air up to cure the problem.
