Ariens GT17 garden tractor repower
Discussion in 'Chainsaws and Power Equipment' started by Horkn, Feb 13, 2019.
  1. Screwloose
    Screwloose
    Awesome news !!
    Hammy, bear 1998, Horkn and 1 other person like this.
  2. Horkn
    That also tells me that the charging system on the magnum 18 is good as well.
    This weekend is probably the weekend where I find out if there are any differences between the output shafts of the kt17 in the ariens and the magnum 18 in the crapsman.
    My buddy asked me if i was going to sell the crapsman frame/ chassis after we pull the engine. I told him yeah, to the recycler...
    To be honest, I might make a trailer out of it. Depending on how difficult it will be.
  3. Horkn
    I am backwards on this on the ariens. The flywheel side runs the " rock shaft" as it's called. That rock shaft runs the transmission and rear hydraulics. The front of the engine has the engine out put shaft that runs the electric clutch for the front and center pto. The magnum in the crapsman it's the opposite. The output shaft is facing the rear and the electric clutch for the front center drive pulleys is in front. No biggie. It's just oriented 180° different than the ariens it will go into.
    Still looking to find the length of the shaft in the kt17 compared to the magnum 18. But everything I can find says they are both 1-1/8" diameter output shafts.
    Hammy, bear 1998 and Screwloose like this.
  4. Screwloose
    Screwloose
    At least the engines all rotate the same direction. In my younger years I was given an engine to put in a pickup. After all was done the truck only had one forward gear but three reverse. Later found out that it came from a boat.
    Hammy, Horkn, bear 1998 and 2 others like this.
  5. trail twister
    trail twister
    Hammy, Screwloose, Horkn and 2 others like this.
  6. Horkn
    From a ski nautique, or correct craft as they were called until the middle 90's? 351w? CC's are the one you can't just put a regular automotive cam in due to reverse rotation.
    Hammy and brenndatomu like this.
  7. Screwloose
    Screwloose
    The engine I messaged you about got stuck in my mind. IMG_20190417_213804923.jpg
    Somehow it wound up in my daughter's Blazer.
    Marvin, Hammy, Horkn and 1 other person like this.
  8. Horkn
    Weirder stuff has happened. :)
    What is the shaft size on that one, out of curiosity?
    Hammy, Screwloose and brenndatomu like this.
  9. brenndatomu
    Kohler powered Blazer...hmm...sounds gutless :whistle: ;) :p
    Hammy, Horkn and Screwloose like this.
  10. Screwloose
    Screwloose
    I'll look tonight. She took it to school.
    Hammy, Horkn and brenndatomu like this.
  11. Screwloose
    Screwloose
    She's a teen going off to college maybe it would be safer.
    Hammy and Horkn like this.
  12. Screwloose
    Screwloose
    Something interesting I found is a company converted these to oil well duty. I don't know how to link so look up "wind wheel engine holtkamp" dang you Horkn now I want one those !!
  13. Horkn
    I was thinking the same thing. At least the Kohler engine would still be running 20+ years later.
    Lol
    Hammy, brenndatomu and Screwloose like this.
  14. Screwloose
    Screwloose
    1.437"
    Hammy, brenndatomu and Horkn like this.
  15. Horkn
    Interesting. I should know more Saturday as to the shaft size in the m18 in the crapsman, in comparison to the kt17's in the ariens.
  16. brenndatomu
    That's an odd size, no?
    Metric maybe...almost exactly 36.5 mm
  17. Screwloose
    Screwloose
    1 7/16" kind of a so so size. Not the most common but still a catalog size.
    Hammy, Chvymn99 and brenndatomu like this.
  18. Screwloose
    Screwloose
    Good luck with it, hopefully it just drops right in.
  19. Horkn
    Yeah that is odd.
  20. Horkn
    Fingers crossed... I've got so many things to do, so if I can get "lucky" on this, my list will be much shorter.
