Argument...wood is going to go bad or not ?
Discussion in 'The Wood Pile' started by Nicholas62388, Oct 29, 2017.
  1. dingbat
    dingbat
    Western Northern Cackalaky
    I burned oak, cherry, silver bell and locust last night that has been heaped in a pile in the mud for over a year. Loaded the stove up at 10pm. Low of 27* with 30mph winds and that "rotten wood" still had my 1700sf house holding at 68* come 5:30 this morning.
    Horkn, BigPapi, WeldrDave and 5 others like this.
  2. FatBoy85
    FatBoy85
    Washington State
    How would you say that silverbell burns? I’m curious, this isn’t a routine name of wood you hear here.
    Horkn, BigPapi, HDRock and 3 others like this.
  3. Backwoods Savage
    There are people who learn and there are people who never learn or even try to learn.
    Check this out: Primer on Woodburning by Backwoods Savage
    As for your wood, it should not be difficult to tell the oldest wood. At least I've not had any problems with wood that has been cut either a year or 2 years.
    You can get by without top covering the wood but your wood will be much better and give more btu's if you do top cover. I've experimented with this a few times and there is a difference. Like stated, it will burn and it will dry but you will lose some btu's if you don't top cover.
    Get the wood split and stacked off the ground then top cover and you can leave that wood stacked for years and years and years with no worries. Thanks to bogydave for his kind words.
    One thing that quite often throws these type of people off is to ask them what about burning pine. I've yet to have one come back saying that pine is okay to burn. Most go bonkers and really warn you to not burn pine. This just shows their lack of knowledge, or their stubborness.
  4. dingbat
    dingbat
    Well as anything else. I've only got a bit of it so it's just mixed in... Haven't really kept a good eye on how fast it burns, but it's fairly heavy when dry, splits easy, and has a cool looking silver/grey streaked color to it.
  5. Jon_E
    Jon_E
    Southwestern Vermont
    Wow that's a new one for me. Had to Google 'silverbell' - never heard of it before.
  6. FatBoy85
    FatBoy85
    Washington State
    I had wondered if it was similar to an apple or cherry. Thanks for informing!:thumbs:
    Backwoods Savage, Horkn and BigPapi like this.
  7. oldspark
    oldspark
    NW Iowa
    I dont top cover my wood (not needed) and I have wood 5 years old (or more) and it is in prime shape.
    Wood rots because it gets wet and stays wet for too long such as in a pile which some people seem to think works.
  8. oldspark
    oldspark
    NW Iowa
    I have seen construction lumber outside for years and not rot.
    Horkn, brenndatomu, BigPapi and 3 others like this.
  9. yooperdave
    Yup!
  10. Mag Craft
    Mag Craft
    South East Wyoming
    Yup here too.
  11. HDRock
    Do you have a wood shed?
  12. MightyWhitey
    MightyWhitey
    Just thinks how much better it would've burned without the mud!!!!:D
    Not true: or the wood the folks have been salvaging from the bottom of Lake Michigan from sunken ships that went down almost 200 years ago would be toast. Not true..............the stuff is almost as pristine as when cut. Don't know the reason; just typing.
  13. FatBoy85
    FatBoy85
    Washington State
    Wouldn’t that depend on being treated or not? I get some soft white pine at a shed building place down the street from my house. The moment it rains then it gets covered in its own pile, it begins to mold which is one of the first ways wood begins to break down. Thus isn’t compartmentalized but with wood as soft as this, its not surprising to see it crumble after a bit. Would really have to be constantly wet though.
    Lumber-Jack, leoht and BigPapi like this.
  14. FatBoy85
    FatBoy85
    Washington State
    Preservation. Many boats did get sealed up in some kind of wax or pitch or tar. Depending on their size and function. There are logs brought up from areas where they dropped for a mill and the logs sank. Preserved by cold water and from other elements that breaks down organic materials. Lots of different kinds of preservation that is natural, right place right time and conditions.
  15. billb3
    construction lumber outside for years must be a pretty crappy lumberyard
  16. Ashwatcher
    Ashwatcher
    West By God Viginia
    I use a wood crayon and put the month/yr on the ends of a few splits in each section as it is stacked just for reference to whats up next to burn or if its a 2 yr dry, to know its not ready-I often will write the moisture content on a couple few also to then re-check prior to use, but then I like playing with crayons....
    And your mistrust of a good moisture meter is unfounded. I like to re-split occasionally just to see how fast it is drying as burning time is approaching or to see how much more time it needs...Your new wood buddy needs to listen more and opine less...:whistle:
  17. BigPapi
    BigPapi
    The hills of Western MA
    Sounds like a cleverly designed ploy to separate you from your well seasoned stash... Hey neighbor.. let me help you burn that wood before it goes bad.. just looking out for ya.. ;)
  18. HDRock
    X2
    If in doubt, check the :woodsign: out :)
    oldspark, Horkn, Lumber-Jack and 5 others like this.
  19. FatBoy85
    FatBoy85
    Washington State
    I need to order more pins for mine. Those things bend too easily.
    Horkn, HDRock and Ashwatcher like this.
  20. MightyWhitey
    MightyWhitey
    The best "moisture meter" is "The 3 Year Plan"!!!!
    Backwoods Savage, J1m and Ashwatcher like this.
