Are you really prepared?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by ivanhoe, Nov 7, 2013.
  1. IHATEPROPANE
    IHATEPROPANE
    They are not a sine wave? Basically created the same way???? Certainly not as smooth and the timing is usually off a bit because it governed by the speed of the engine...mine runs at 60.3 and will vary a bit upon load.
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    Ok fella's. Lets take a breath....
  3. IHATEPROPANE
    IHATEPROPANE
    [​IMG][​IMG][​IMG]
    I hope these pics show up ...hopefully this will bring some clarity and be useful to someone
    A good "pure or true" sine wave inverter will look like the second picture...
    A regular generator will look like the first pic...a real sine wave with some distoration
    The third pic is of a modified sine wave, there are others and you can see it is very different from the others, some motors and power supplies will not like that one very much....most things couldn't care less about any of the three
  4. imacman
    imacman
    Denver, NC
    In the case of our pellet stoves, the need for either a pure sine wave output (or at very least something close to it), it due to the electric motors for the blowers. They start to hum and get hot with a mod. wave....not good.
    jtakeman likes this.
  5. smoke show
    smoke show
    Pittsfield, Wi
  6. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
  7. tinkabranc
    tinkabranc
    South Coast, MA
    Both my stoves are plugged into UPS for quick blips in the power.
    They will keep the stove going for about 30-45 minutes or so with the stove on low. Gave me time to dig out the generator when needed.
    Used to have a 10kw portable generator and hard wired transfer switch in the house. Man that thing was a hassle when it had to be dug out when there was two feet of snow on the ground.
    No garage.
    sold it all and eventually had enough $$ to upgrade to a 17kw standby that runs off NG.
    Longest it ran at one time was 30 hours from a blizzard about 3 years ago. Stoves run just fine with it.
    eatonpcat, imacman and jtakeman like this.
  8. imacman
    imacman
    Denver, NC
    NICE!!
  9. ivanhoe
    ivanhoe
    Northern Ontario
    Again it happens! Power out from 6:30am to 8:30pm but this time I was home. I had to work the night shift so I again left with the battery back-up purring. I fired up the generator for a couple of hours so my fridges & freezer stayed cold as I was in the dark for when the power will go back on. Just ranting away as this inconvenience is getting the better of me. So ask yourself, are you really, really prepared?
  10. mike holton
    mike holton
    Old Dominion
    i got a log burner on standby in the garage (no it aint hooked up) along with piping needed to convert from pellet to wood would take me 45 minutes to go from a dead pellet stove to a struck match have already done it once
  11. bearverine
    bearverine
    Winchester, Indiana
    2 pull start gennies at the house. Nice electric start gennie in Pop's barn. 1 old pull start in his. crib shed. Juuuuust in case.
    None of them very good wave patterns. Although last time I sat the nice one up for Dad, he was out there chillin' like a villain and watching TV all day. I had to laugh at his description of it.
    He has a propane fireplace, as do I. I am fortunate to also have the insert upstairs. We can hold out for awhile.
    ivanhoe and IHATEPROPANE like this.
  12. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Ahhhh, A PTO GEN SET.
    What size and make.
    We recently bought a new Mahindra 22 HP 4x4 tractor and having a PTO gen set would be sweet.
    IHATEPROPANE likes this.
  13. StEarl
    StEarl
    millinocket, maine
    genny is hooked up and ready to go. ground wire attached with copper pipe pounded all the way down into the ground, exhaust plumbed out the back of the shed. the pipe fittings are very tight over the nipple on the muffler and i could probably run it just fine even w/o the high temp silicone.genny has 100% copper wound heads, thd <5% , and all the electronics run just fine off of it.
    the voltmeter stays rock solid, and the stove motors don't hum or complain in any way. the last outage was 4 hours.
    i have the extension cord running under the floor up into the living room with the other end coming out through a hole in the pellet bunker hatch near the shed. and all the secondary cords inside are on a power strip and ready to go at a moment's notice.
    subsailor, milleo and IHATEPROPANE like this.
