Are you really prepared?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by ivanhoe, Nov 7, 2013.
  1. will711
    will711
    Pocono Mts.
  2. subsailor
    subsailor
    Winthrop, Maine
    Are these pure sine wave like the one Woody posted?
  3. IHATEPROPANE
    IHATEPROPANE
    Regular generators are ac and are already a sine wave like utility power....just not as clean but should not hurt anything you own unless it runs out if gas then the possibility increases.
    "Pure" sine wave is terminology used when discussing inverters going from dc to ac to distinguish themselves from the modified inverters which are not like what comes from utility.
    Most electronics nowadays can deal with any incoming power from 50-60 hz and 100-240 volts....check the power supply for your tv for instance.
    I wouldn't worry at all about running a regular genny
  4. DexterDay
    DexterDay Administrator
    Northeast Oh
    They say they are. The one I won on an auction (FeeBay), and was just over $100. Its the same as this model here, but branded by Duracell (this same unit has like 3 or 4 different names and colors).
    The other was a little more expensive. But reads the same
    Pallet Pete likes this.
  5. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Ooo Petey likey ! Gonna have to find one of those Dex all we need to run is the fridges for an hour or so a couple times a day.
  6. IHATEPROPANE
    IHATEPROPANE
    FYI ETQ is out of business. Same brand as my inverter....was also the same as Generac and Honeywell I believe. Like Dex said they go under a few different names. I can say that my Etq inverter is dead on at 60 hertz and 121 volts. Good unit for the money....only issue was the economy mode button was reversed....silly Chinese
  7. Woody1911a1
    Woody1911a1
    Marblehead , Mass
    fyi i think you'll find yourself hard pressed running a fridge on a 900/1k genny . buy yourself a kill-a-watt like $25 at hd and check the spike at compressor start-up . :)
    bearverine, savemoney and Pallet Pete like this.
  8. Pallet Pete
    Ovid
    Good idea thanks.
  9. Woody1911a1
    Woody1911a1
    Marblehead , Mass
  10. jtakeman
  11. savemoney
  12. IHATEPROPANE
    IHATEPROPANE
    In addition to Woody's comment it is not recommended to run inverter generators near their max rating.....the inverter modules get hot and it can lead to premature failure...ideally you only use 50% or less so I am told
  13. subsailor
    subsailor
    Winthrop, Maine
    Well if that's the case, I guess I have nothing to worry about. Except my 2500 watt drinks gas like I drink beer. Vast quantities.
  14. IHATEPROPANE
    IHATEPROPANE
    Lol....this is true, they can be thirsty
  15. Woody1911a1
    Woody1911a1
    Marblehead , Mass
    that's not really the case , but i'm not in the mood to argue right now . do due diligence research on the subject :)
  16. subsailor
    subsailor
    Winthrop, Maine
    Okay?:confused:
  17. IHATEPROPANE
    IHATEPROPANE
    EDIT: Erased my comment...missed the post about him mentioning his Honda 2500..whoops
    subsailor for comparison my Champion 3500 watt regular generator uses 4 gallon in 12 hours at 50% load
  18. Woody1911a1
    Woody1911a1
    Marblehead , Mass
    regardless of what ihp says , ac out of a motor connected to an alternator (your basic non-inverter genny ) is NOT the same as the ac from a true sine wave inverter genny . period .
  19. IHATEPROPANE
    IHATEPROPANE
    When did I say is was the same????
    Can you read my quote
  20. Woody1911a1
    Woody1911a1
    Marblehead , Mass
    you said " Regular generators are ac and are already a sine wave like utility power.."
