Are any of you seeing a resurgence in pellet stoves?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Orson_Yancey, May 10, 2026.
  1. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Me cook,it all went next door, and the corn meal opened up, not a happy camper be I.
    imacman and jtakeman like this.
  2. JD Guy
    JD Guy
    Upstate SC
    Resurrecting an old thread, my apologies:whistle: We use propane only for the cooktop as when we were remodeling and increasing the sq footage of the house wife said had to be gas! We have a 100# cylinder that we own and typically it gets topped off once a year just prior to Thanksgiving. Recently the regulator leaked and the tank is empty. Replaced the regulator and gas company won’t refill until its pressure tested at $100. Is this normal? It’s taken them about a month to come and test it so consequently no use of the cooktop. Thinking of replacing this tank with the larger 120 gallon tank to eliminate yearly refills. Is this way overkill? Thinking ahead to having a propane fired generator so this is my logic. Might just change suppliers too as they are pretty hard to deal with but I understand that I’m a small user to them. I Would purchase my own tank as that wouldn’t limit my choice of suppliers. Thanks!
  3. Orson_Yancey
    Orson_Yancey
    Portsmouth, NH
    For a propane generator, you need at least a 120 gallon tank to provide enough surface area for the propane to boil off
    during coldest nights in the winter to supply propane gas to the generator. Coldest night, worst case. A propane supplier supplying their
    120 gal. propane tank will charge a rental fee. I suggest that you own your own ASME 120 gal. tank. It will cost $1,000 to $1,500.
    You will also save money of paying a lower price for propose because you will be able to negotiate and purchase from any
    propane supplier. Any propane supplier can fill a tank owned by the customer. But check your State's laws for sure.
    After you are finished using an ASME propane tank, as a used tank, it still has substantial value to sell to the next individual.
    imacman and bogieb like this.
  4. JD Guy
    JD Guy
    Upstate SC
    Thanks for the great advice! We very rarely lose electricity during winter months with a freak ice storm being the exception. Our power outages are more likely in warmer months due to storms or the last hurricane Helene where it was down for 9 days.
  5. Highbeam
    Highbeam
    I run my propane generators from 20# BBQ tanks. No problem running the 4500 watt water heater during the outage, though the ambient temps were above freezing. The smaller propane generators, like my little 2500 watt dual fuel units, are designed to run from 20# BBQ tanks in any weather.
    A huge 20 KW unit, yeah, might want the big 120 gallon pig. Propane generators are awesome.
    Orson_Yancey, imacman and bogieb like this.
  6. brenndatomu
    How long does that last?
    imacman likes this.
  7. Highbeam
    Highbeam
    For the champion 2500 I am supposed to get 34 hours at 25% load on a 20lb cylinder according to the specs. I then acquired 8-20lb tanks!
    My big hoss costco firman genset would run for a shorter time but it was tested to work at high output from the BBQ tank. The "generator bible" lists that this genset will run 5-6 hours at 50% load from a 20lb tank. It's loud and a non-inverter so is only run for high wattage needs like a well pump or water heater.
