Are any of you seeing a resurgence in pellet stoves?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Orson_Yancey, May 10, 2026.
  1. Orson_Yancey
    Orson_Yancey
    Portsmouth, NH
    Just based on the questions my neighbors are asking me, it looks like there is a slight resurgence of
    interest in burning wood pellets. Most likely due to the ~$5.00/gallon heating oil prices.
  2. jtakeman
    We have been keeping an eye one 2nd hand stoves on FB market place. Prices have increase a bit IMHO. I would imagine if prices on HHO remain high stoves and mini split sales will increase by a large percentage.
    I haven't tracked NG or LPG, But I imagine those also rose by good margins. That should also effect stove and mini split sales as well. Wish I had a 3rd flue, I'd add a wood stove as it still remains the cheapest form of heat if you don't mind the added work involved!!
  3. bogieb
    Interestingly propane hasn't really increased too much for me (not like gasoline anyway). If I were to get a fill up today it would be $4.55/gallon and I previously paid $4.25/gal. I pay a high price because I use little (mostly for hot water) and only get a fill up about every 18 months.
    HOWEVER, they sent a notice last week that they will start charging a rental fee for tanks at $39/year. I am unsure if that is per tank (which I have 2x100 gal tanks), or just as a whole (my home set up). Their wording is a bit ambiguous as the notice says:
    Unfortunately I am still at about 65% level, so can't even look around for another supplier until it get a lot lower. If it is just $39/year total, then I can live with that to have it as emergency backup heat thru my FHW boiler. If it is $78/year, that makes me think a bit harder about it.
  4. Canadian border VT
    bogieb a 100 pound tank new a BBS are 160 dollars so for 300 dollars if they are yours usually any one will fill cheaper
    MikeInMa, jtakeman and imacman like this.
  5. imacman
    imacman
    Denver, NC
    She has (2) 100 GALLON tanks, not 100Lb. (actually I think they're 120 gal, but never get filled past about 100 Gal). Those tanks go for around $800 +.
  6. Canadian border VT
    Thanks :handshake: but 2 quarter rounds (yes they are 120 gallons) for why have 2? Most suppliers here drop one..
    bogieb look at electric hot water heater with a (like mini split) on top I have seen a rheem at Home Depot for 850$ As you have solar it might be cheaper with benefits of dehumidifier in basements
    MikeInMa and imacman like this.
  7. jtakeman
    She did IIRC right before I installed mine. Great in the summer months as it cools the area much like an a/c unit, But you must look into venting outside during the winter. The area it is installed in will get chilled. And even with it venting outside, You will still notice that area getting a cooler than normal. So heating said area's cost will rise slightly. I never tried to figure out the offset. But the hybrid water heater did drop out monthly electric bill by $30 or so.
  8. Canadian border VT
    Ok jtakeman I looked, at them actually put one in rental units BUT to get rebates here had to be installed by Energy star certified And used 12 months out of year.. then unit was $3,850 and labor $125 an hour now that most rebates ended the unit is $850 with $300 electric company rebate so it can have reasonable payback period
    MikeInMa, imacman and jtakeman like this.
  9. bogieb
    I had 2 tanks installed, instead of 1, because my boiler is propane and is my 3rd option for heating (when temps are in single digits or below it is my 2nd option). I replaced the behemoth of a 500 gal propane tank years ago, when I changed from the original company that came attached when I bought the house. The two 120# tanks sit next to the house instead of in the middle of the yard too.
    Old tank could be seen from road and backyard. Only place it couldn't be seen was from the opposite side of the house.
    2 x 120# tanks
    I'm not looking to get rid of propane. Early 2023, when my water heater failed, I replaced the 30+ year old boiler and water heater with a combi-boiler. So no pilot lights and the hot water is on demand. I gained a ton of space in the basement since the system is direct vent wall mount (ton of space meaning about 70 sq/ft - when you have a 650 sq/ft basement, that is a "ton"). I could run this system off of a small power station during a power outage if needed (it's on the same 120v outlet as the P61a). I also have a propane cook stove. So I'm not looking to get rid of propane
    Old boiler on the left along the stairs and water heater on the right (not only gained space, but also got rid of the exhaust to the chimney across the opening, which I had to duck under.
    Combi boiler
  10. Canadian border VT
    My wife won’t give up her propane stove either!
  11. Orson_Yancey
    Orson_Yancey
    Portsmouth, NH
    I would strongly recommend that you purchase your own tanks. It looks like you have 120 gallon tanks.
    MikeInMa likes this.
  12. bogieb
    Sure, you cough up the money for the tanks ($800 each), regulators, testing every 5 years (after initial 10 year qualification), and I'll be happy to :D
    I already looked at that when I changed providers years ago. It was expensive then, and even more so now. At the tank rental price of $39, I can cover the price of 2 tanks in just 40 years (which would put me at well over 100 years old).
    stoveliker, MikeInMa and imacman like this.
  13. bogieb
    Not that I use it often. But, in a power outage it is the best option for cooking/heating up food. Cooking with anything electric uses a high amount of wattage.
    Canadian border VT and imacman like this.
  14. Orson_Yancey
    Orson_Yancey
    Portsmouth, NH
    I purchased ASME tanks which never need to be re-certified. Moreover, when a person owes their own tanks, a person can negotiate with
    the propane suppliers because a person can easily change suppliers. A person can negotiate for the lowest price.
    This past winter, I paid $2.79/gal. for a usage volume to 250 to 350 gallons.
    I estimate that a person will save about $1.00 per gallon in propane costs, by owning one's own tanks. The savings if reduced propane
    cost and no tank rental charges will amortize one's one tanks in 6 to 7 years.
    The propane industry in New England is very exploitative; the propane suppliers lobby hard in the state government.
    It make no sense that the propane supplier owns the tank that is buried on the property of the customer.
    There are really no logical reasons why the cost of propane should be 2 to 3 times as expensive as in the Mid-West.
    However, New England could use one or two more pipelines, but the local people lobby against it.
    bogieb and Canadian border VT like this.
  15. Canadian border VT
    All good points sir, BUT a cost benefit analysis does have to be done. Do you happen to have a source for the tanks you could share?
    imacman and bogieb like this.
  16. bogieb
    Glad that works for you.
    Over an 18 month period I use about 168 gal. ASME tanks are even more expensive than the others that need recertified at $1,300 per120 gal tank. At $1/gal savings (or even $2 savings), it would take about 20 years to recapture the cost of the tanks plus hiring someone to install plus all the attachments/regulators etc.
  17. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
  18. jtakeman
    You ordering pellet stove parts?
    imacman likes this.
  19. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Nope,new mouse and a spare along with some clean corn meal to play with.
  20. jtakeman
    Corn meal??
    I just ordered live meal worms.
    SmokeyTheBear and imacman like this.
