App says Ash
Discussion in 'The Wood Pile' started by CutSplitStack, Feb 27, 2025.
  1. Horkn
    That's odd. It sorta looks like a couple of species, then there's something that says no way it's that. What's the moisture content of it? And is it heavy? I'm leaning towards some sort of willow. I see willow leaves in the pile.
  2. CutSplitStack
    CutSplitStack
    SE WI
    Confirmed willow from the leaves. Looks like a long seasoning window. But...I do have a set of privacy panels to do for the patio, and we had talked about doing wood stacks instead for a cool look. This could be the ticket, bc once I split and stack them they can sit for 3 years undisturbed!
  3. Horkn
    Once it's dry it burns, but the reason I don't mess with willow, is due to the long time it takes to dry, and then you'll only get 14 mbtu a cord out of it. I can get the same BTU's out of poplar, basswood, or pine/ fir in that amount of time. I get more BTU's 17.9 mbtus out of box elder in 1 summer drying, and I can get box elder without even trying around here. That's why I didn't bother with willow. Honestly it's the only wood I won't cut unless it's fallen where it's in the way or an eyesore, and then I just haul it away and let it rot.
  4. CutSplitStack
    CutSplitStack
    SE WI
    Makes sense. This job was a favor to a buddy, and it might work out well to have these splits sit long term, vs filling that space with better splits that I'll want to burn!
  5. Horkn
    BTDT as well. It was a yard tree, and we did split it and it was used for outside fires. I don't make a habit of doing anything with willow though.
    buZZsaw BRAD and brenndatomu like this.
