Hello This seasons heating is tough! I got our 3 Tons of wood pellets that went up in price and 138 gallons of oil that went way up in price On the EcoSmart DHW instant on demand hot water panel, I had to fix a blown #1 heating element and fix a burned 8 Guage power wire and connector because it burned before the 40 amp breaker tripped in the circuit panel. See EcoSmart 27 OnDemand Electric DHW panel heating element replacement - Copper or Titanium? Then I had to patch a leak in the heat exchanger copper pipe and will test that today! Just trying to get back to normal! Hope that special black Weld On copper pipe sealing tape and JB water weld holds up? The JB water weld is rated at up to 4370 PSI and 250 Degrees F. So far the Good News! The initial findings are No Leak !! Back to NOIL !! That is No Oil !!! So there was no way to get in there and resolder the connection. Eco Smart says to replace the whole heat eachanger. It would easier to just replace the whole panel but not cheap! See black Weld On pipe tape under white JB Water Weld patch between heat element 1 & 2 housings reading from right to left in last pic. Has anyone used this on warm pressurized small copper pipe leaks?
