Anyone using a single axle dump trailer?
Discussion in 'Chainsaws and Power Equipment' started by EODMSgt, Apr 7, 2021.
  1. Boiler74
    Boiler74
    West Lafayette, IN
  2. EODMSgt
    EODMSgt
    White Mountain Region, NH
    While I would prefer to have a longer trailer with the dual axle it would not be practical for the location I would primarily be using it in. My scrounging area is usually within a 10-mile radius from home so it would not be an issue to just make multiple trips with a smaller trailer.
  3. EODMSgt
    EODMSgt
    Thanks, but as mentioned previously, I think a 10' trailer is too long for the location I would mainly be using it in. Two feet doesn't sound like much of a difference until you're trying to turn around on a narrow forest service road with a 100' drop off.
  4. Rope
    Rope
    Alaska
    I like the way your thinking! I think the trailer your looking at makes sense for a 1500. Add that you scrounge less than 10 miles from home, and the maneuverability of a single axel. The trailer in my opinion will absolutely be a really good fit for your application. And will save so much wear and tear on your truck. Does it have brakes? Worst case you can always sell for a different trailer if you change your mind on the size.
    24FCA211-CF2B-4C0F-AE14-9E04606650B4.jpeg This is my 2500 with a 14’ I wouldn’t want any more trailer without upgrading trucks to a 3500.
  5. Rope
    Rope
    Alaska
    I have made 4 trips with wood, loading without worrying about breaking glass, denting anything. Loading is fast and unloading even easier.
  6. amateur cutter
    That's a good looking combo there Tom, but where's the snow?
    EODMSgt, Chazsbetterhalf and Rope like this.
  7. Rope
    Rope
    Alaska
    From October when I bought the tractor and trailer. Here is a picture I just took, that’s the rink next beside the deck. @ 57 today it won’t last long.
  8. jo191145
    jo191145
    Ct
    I have a 6x10 single ram and have never heard it balk at all with a full load of logs. Been known to go well over ratings.
    It was something I was concerned about but turned out to be a non issue.
  9. jo191145
    jo191145
    Ct
    I think the trailer will serve you well for the conditions you describe. The 1500’s sure do ride nicer. Would have bought one of those instead of my 2500 but couldn’t find a decent plow to go on one.
  10. TurboDiesel
    I like this ^^^^set up!!
    I think you'll be fine with that dump.
    My only concern on trailers is how the push cylinder is always so far back in the middle of the bed. Its practically lifting the entire load right from the center
    but thats how they get the bed angled up to empty. Just seems too hard on the cylinder.
    If you over do it youll be shoveling the load back to get it started up. (I'm picturing a load of stone)
  11. EODMSgt
    EODMSgt
    Nice setup! Before I traded in my Ram 2500 I was thinking of getting a tandem dump trailer so I could also tow my tractor. After deliberation, I realized I would only maybe trailer it once or twice a year, if at all, so it wasn't worth the investment to get the trailer. I think the single axle dump will be the way to go now that I have the 1500.
