Anyone use Trufuel?
Discussion in 'Chainsaws and Power Equipment' started by corncob, Jan 20, 2023.
  1. Dok440
    Dok440
    NorCal
    I have had that happen once. I still buy it but if the price of Husky or RedArmor fuel isn't outrageous, I'll opt for them.
    metalcuttr, Horkn and Screwloose like this.
  2. Rickyblazin
    Rickyblazin
    Pottstown PA
    Yup
  3. yooperdave
  4. corncob
    corncob
    Somewhere in Lower Michigan
    I never knew chainsaws came with them until I looked at the parts breakdown. I will leave the USDA spark screen intact however. None of my other saws have one but then they are older saws and all have had the muff mod anyway.
    The Trufuel I bought has no stink at all and the Stihl pre mix don't either.
  5. KSPlainsman
    KSPlainsman
    Kansas
    Someone on OPE ran into a cat in their muffler a couple months ago. Before that, I never knew it was a thing either. They said it was a bit of a bear to get out, if I'm remembering correctly.
    Screwloose, metalcuttr and Horkn like this.
  6. Farmchuck
    Farmchuck
    Nepa
    This maybe a stupid question but I’m famous for those. How do you know if your saw muffler has a cat in it or not? What does it look like? Is it part of the internal muffler or a separate piece? Thanks.
  7. Screwloose
    Screwloose
    It looks like a honeycomb screen that the gasses pass through.
    metalcuttr, KSPlainsman and Horkn like this.
  8. Horkn
    It's internal. Your never know it unless you open up the muffler
  9. Eggshooterist
    Eggshooterist
    Erff
    They can be. Bypassing is a better option if doable
  10. KSPlainsman
    KSPlainsman
    Kansas
    It sounds like that's the way to do it if possible. I was thinking he ruined a couple drill bits trying to drill it out. That's all if I remember right. I've never seen one in person. So I'm not familiar, other than a few pictures online.
  11. Ohio
    Not Ohio
    I removed the cat in my echo pole saw. Was a real PIA. 0629211848b_Film2.jpg
  12. Eggshooterist
    Eggshooterist
    Erff
    I've removed 3-4. One crumbled like it wasn't metal. The others were a complete pain. The last 2-3 pieces of ope I felt the need to remove the cat, I just bypassed with strategic drilling. I mod everything lol.
  13. Ohio
    Not Ohio
    I almost went the route of just drilling enough holes in the metal baffle to compensate for the cat. It looked flimsy but was very durable and put up a good fight.
    The tech at the dealer said don't over do it because the carb may run out adjustment room if opened too much. Whether that's true or not I don't know.
  14. Eggshooterist
    Eggshooterist
    Erff
    I haven't ran into that on an otherwise stock engine as of yet. I've put a 3/4" id "stinger" on my 25cc echo leaf blower after bypassing the cat. That said I could see it happening with the right carb / engine combination though.
    Horkn, Farmchuck, Screwloose and 2 others like this.
  15. MasterMech
    Catalyst mufflers have been a thing for nearly 20 years now on handheld OPE. They are similar to automotive catalytic converters in function and construction. Yes, they are ceramic and will tear up a regular twist drill instantly. Prob better off with a masonry bit in a hammer drill or the old-fashioned punch/prybar/screwdriver and a hammer. I highly advise precautions against breathing any dust.
    RE:TruFuel - good stuff, even if it goes stale, it does not kill a carburetor/fuel system. Drain, refill, go. I use it in my newer M-tronic saws, they re-tune themselves to it (from pump gas) perfectly and I don't have to worry about them sitting too long with pump gas in them. More of a concern for me since the saws are used infrequently now. :tears: Very expensive if you run through more than a few gallons a year though. If you reliably burn through a 1+ gallon can of mix in a month - prob better off to mix your own with pump gas.
  16. RCBS
    RCBS
    Over here
    Have not used Trufuel brand. I adopted canned gas pretty early. Been using it since 2015. I do not use it exclusively. Prefer Red Armor, but have run gallons of the Husky stuff. My weedeater drinks too much gas to fill it with the high dollar stuff. Will use regular pump and mix if I know I'm going to run through a lot of fuel. Current price I'm paying for Red Armor cans is $7.50 as of 3 weeks ago. To get that price, I have to find myself at a saw shop that's half hour away. Great shop though. Glad I found them.
    Screwloose, Horkn and KSPlainsman like this.
  17. Rope
    Rope
    Alaska
    I used a gallon Trufuel a few months back, in a stock 362 CM no issues. Burned through the gallon in a few hours after going through 2.5 gallons of none-pump gas with Saber. I couldn’t tell any difference between them. Price is my issue with canned fuel. TruFuel is the cheapest at $24.99 a gallon. A quart of Ams oil Saber is $14.99 @ non-e fuel is $3.89. I make my mix by the 5 gallon can I burn though that every 6-8 weeks.
  18. Horkn
    I can tell you that the Sabre mixed gas Smells a ton better than true fuel premixed. :handshake:
  19. Eggshooterist
    Eggshooterist
    Erff
    The red true fuel 50:1 stuff smells just like echo red armor to me. Which is like a combo of melted crayons and coconut. I hate coconut.
  20. Screwloose
    Screwloose
    Melted crayon!!!!!
    Ever hear the story of the idiot who sent a red lumber crayon through the clothes dryer?
    Not a good day......
    Horkn, KSPlainsman and Eggshooterist like this.
