Any tips for snow plowing?
Discussion in 'The DIY Room' started by JackHammer, Jan 23, 2022.
  1. eatonpcat
    This little fella does my 500'+ driveway!
    EODMSgt, Warner, Eric VW and 5 others like this.
  2. Canadian border VT
    I got one of them yup 50 HP will effectively clear a 13 foot driveway see avatar pic
    edit eatonpcat did aforementioned driveway for 3 years with a 2 foot push Honda to pay for 78” meteor blower and chains paid my self 40 a time
    EODMSgt, Eric VW, Jack Straw and 3 others like this.
  3. Flamestead
    Flamestead
    Windsor County, VT
    You might think of plowing with the blade straight as being like using a bulldozer: you load the blade and then carry the load. In this case, you want to minimize the carry distance. If this is not an option (long carry) and you have adequate traction, try using a slot technique to increase the amount you can carry on the blade (the snowbanks of the slot help keep snow from spilling off the blade as you carry).
    Eric VW, Jack Straw and JackHammer like this.
  4. JackHammer
    JackHammer
    Thats great advice. Thank you. I didn't really think in terms of a bulldozer, but that makes a lot of sense.
    I started doing this on accident a few days ago when we got 18 inches. Maybe next time around I can be more intentional about it.
  5. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    With a smallish machine like that, and a good distance to cover, I’d likely start on one side with the blade angles to push snow to side of drive and follow that all the way out of it’ll do it, and then continue doing the same on smaller snow events. But if substantial snow happens, same idea the first time and then kinda use that one mower swath as a way in to push sideways and angled a bit with the blad mostly straight but probably a little angled to where you’re going, if that makes sense. As was mentioned above, shorter distance to “carry” the snow will help tons.
    I clear the snow for our school and have found I must do the same, even with a held pickup and plow and skid steer. With a heavy snow, you just can’t push it as far usually.
  6. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Plow with the storm if you are getting more than 6 inches, it’s so much easier to move 6” than say 12”. You may want to plow even more if the snow is wet. Wet snow will be hard to push and very hard with the plow angled.( your front end will want to move to the opposite side you are plowing) In heavy snow make room so you can speed up before you start to plow. Weight is you friend!
    Good luck!
  7. Redneck
    Redneck
    Burton mi
    Just move south and wait til it melts. Then move back home. Snow Birds.
  8. Stephiedoll
    Stephiedoll
    Omaha, NE.
  9. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Picked it up in February that year. No snow until 2 days after finding/stealing it. I try to take care of as many neighbors as I can, and last snow was 15 driveways. Keeps me young.
    The kind of snow we received just after purchasing it.
  10. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    This would be neat.
  11. Woodwidow
    that is neat. Fun to play with but very time consuming if there was a lot of snow.
  12. chris
    chris
    SE WI
    plowed commercially for many years. Every lot is different and the amount of the snow fall can and will change your approach to any particular lot. With deep heavy snow most of the time you will have to start by making an area to move the snow over to, seems counter intuitive , but if you start at the far side to keep moving it over you will reach a point that you just can't move it any more. Then you are going to spend a lot of time trying to pile it higher to make room for the next storm. Most of my accounts all had one or more truck docks the easy ones were just flat the hard ones were where the dock is at main area level and the approach to the dock was a big hole. Lot of back dragging on those. Worst case we would get out the 10-15 hp walk behind blowers to clear it out. As there is always wheel chocks buried in there went through a lot of shear pins. Worst one was only apx 10 ft wide and apx 1 pickup truck long at apx 45deg angle. That sob would get a newbe stuck every time, no traction due to the angle. When piling snow or at the end of a long run you have to be aware of not going to far into the bank and overeaching you plow lift- otherwise you will be hand digging the plow out to get unstuck. just some tid bits from 25 years of plowing.
  13. Jack Straw
    Jack Straw
    Some great advice there! You think you can remember what a driveway looks like until there’s 12” of snow on it. Markers for curbs and other obstacles can prevent serious damage. I’ve found lots of things in snow with a walk behind blower. People walk their dogs through large parking lots while you are trying to plow it. Plowing looks fun, but It isn’t :yes:
  14. corncob
    corncob
    Somewhere in Lower Michigan
    My tip is stay in the house where it's warm and pay someone else to plow it.
  15. Warner
    Warner
  16. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Never thought of that. Previous owner said it came as a package with a spare, but you could be on to something.
  17. chris
    chris
    SE WI
    I have also used a rear mounted plow, mostly for the truck dock pits, Worked great much better than back dragging, but you really have to watch out for approach angles when entering or leaving parking lots, rebuilt/ modified the mount before I got rid of it. Steep approach wood bottom out the rear plow bending/ breaking oem mount.
  18. MasterMech
    The novelty sure does wear off quick. Especially if you're out of the tractor/truck dealing with problems much.
    If you're just doing you're home/farm/business etc. and you control what is and isn't left out for the winter, it ain't so bad. Can be just another chore.
    JackHammer and brenndatomu like this.
  19. MasterMech
    The 17HP Kawi one-lung on those little tractors is strong but not THAT strong! :rofl: :lol:
    For bigger tractors (CUT size and up....) Front-mounted blade and a rear-mounted blower can be a formidable machine especially where a good clean end-result is mandatory.
  20. huskihl
    huskihl
    I still say get a Boss
    mat60, Chvymn99, JackHammer and 5 others like this.
