Any special considerations for burning oak?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Lil'John, Oct 14, 2014.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
    Hello John welcome to the forum! I see you're getting loads of good advice and hope you also hear from Backwoods Savage our resident firewood expert to provide further guidance.. Good luck!
    Ray
  2. raybonz
    raybonz Moderator
    Carver, Mass.
    Oh a couple more things.. I suggest you try a top down fire.. Place heavier larger wood at bottom then kindling and lighter wood up top then place a Super Cedar firestarter on top.. This will serve 2 purposes.. One it will allow your flue to warm up quicker and two it will reduce smoke on startup.. In lieu of Super Cedars you can place rolled up loosely knotted newspaper on top of the kindling. You can buy Super Cedars here:
    http://www.supercedar.com/
    I cut them into 6 or 8 pieces but many folks cut into quarters.. Either way they work great and I can start a fire with no kindling with these..
    Ray
    Tenn Dave and Chvymn99 like this.
  3. raybonz
    raybonz Moderator
    Carver, Mass.
    Go here for discount code for Super Cedars and I am pretty sure they will send free samples for you to try them.. You will love them!
    http://firewoodhoardersclub.com/for...iscount-code-for-fhc-members.2492/#post-53960
    Ray
    Chvymn99 and Oldhippie like this.
  4. Lil'John
    Lil'John
    Glad I asked for input. I had a reasonable "day and a half" burn. It seems like the new late night habit I need to start is hit restroom, drop log on fire ;) I didn't do it last night and it was barely coals this morning. On the other hand, I dropped a log on the barely showing coals and pulled the air fully out. Surprisingly, it caught fire and has been good for the day.
    With the recommendation of "Super Cedars", I have to ask: Is there a downside to them or risk to the soapstone insert?
    My neighbor recommended something similar but I'm being a little gun shy on them.
    wildwest likes this.
  5. wildwest
    Gasifier ?
  6. Gasifier
    No. No. Last time I saw heard something like that smoke show was "currently destroying the bathroom at a Sears store!" :wacky:
  7. smoke show
    smoke show
    Pittsfield, Wi
    :emb:
    Gasifier likes this.
  8. Gasifier
    :rofl: :lol: I still laugh about that post every time I go to the mall and see Sears.:rofl: :lol:
    wildwest and smoke show like this.
  9. jharkin
    jharkin
    I like to treat them as separate concepts. The chimney is structure and the flue the individual "pipe" inside of it, either clay tile or metal pipe. Very common for chimneys to have more than one flue - especially in older homes and masonry construction. But you can also have a wood framed chase with multiple steel pipes running through.
    For example I have 2 chimneys on this house that contain 4 flues (one has 3, the other 1). Ive seen some grand old chimneys with as many as 5 or 6 flues. Even in mid-20th century construction its common to see brick chimneys with at least 2 flues (one for fireplace, one for the furnace).
    basod and concretegrazer like this.
  10. basod
    basod
    Mount Cheaha AL
    As far as the wax melting and absorbing into the stone - I think the manual recommends against them for that reason.
    Using a small piece of starter I wouldn't be concerned, just don't use the pressed wax logs as a main fire source.
    Glad your oak is burning well on a coal bed
    Chvymn99 and concretegrazer like this.
  11. concretegrazer
    concretegrazer
    Southwest MO
    Super Cedars are safe to use with soapstone.
    raybonz and basod like this.
  12. Lil'John
    Lil'John
    Hmm... guess I should drink lots of coffee before posting.:doh:
    No I'm not burning dried manure in my fireplace:emb:
    concretegrazer and basod like this.
  13. raybonz
    raybonz Moderator
    Carver, Mass.
    Perfectly safe to use in any stove.. Many WS stove owners use them here and I have used them in a cast iron and now a cast iron stove with a steel firebox.. Post to SC and they will send a couple to try out for free.. You'll be hooked after that! They are great for shoulder season when I start so many fires..
    concretegrazer likes this.
  14. Lil'John
    Lil'John
    I would love any clean up hints.
    On the top-down method, my first attempt failed beyond miserable. I'm on my second attempt currently and while not failing, I'm still scratching my head a bit.
  15. raybonz
    raybonz Moderator
    Carver, Mass.
    http://www.woodheat.org/top-down-fever.html
  16. raybonz
    raybonz Moderator
    Carver, Mass.
  17. basod
    basod
    Mount Cheaha AL
    the top-down method is overrated IMHO - could be the size of Clydesdales firebox or lack of a good draft(shoulder season) No reason to try it when the stove is already hot w/coals when I have good draft
    I tried it 4-5 times and went back to building fires like every pyro does - paper, small twigs, bigger sticks then small splits.
    As for clean out:
    The vertical pieces of stone need to be removed, 7/16" socket with extension, or nutdriver if they aren't over tightened - just loosen the side strap bolts(1-2turns) and slide the bracket off, a piece of cardboard or old drop cloth to lay them on outside the stove. Remove the rear strap bolts all the way(they will get in the way of dropping the baffle) remove stones.
    The baffle and tubes are held with 2 allen hex cap screws(i'll get back on the size allen wrench) they need to be removed completely - the baffle won't drop so don't worry there.
    Lay your hands flat across the baffle tubes towards the front of the stove(try not to touch the plate above) elbows on the ashlip, push up and then pull forward, change one hand to brace the back of the assembly and lower it into the bottom of the stove. No reason to take the baffle& tubes out of the stove, just put a piece of scrap plywood on top of the baffle and sweep top down(or bottom up if you get a sooteater).
    There are 4 screws holding the baffle in place with clamps on each side - I'd recommend removing them with a short #2 Phillips screwdriver and anti-seizing them only snug tight every year that you do full clean out/sweep...just incase your baffle ever breaks. I went back with allen hex caps on mine(and have more than enough PM me if you'd like some).
    Lift the baffle (using the tubes as support) and slide it back over the rectangular air ports in the rear of the stove - lift from front, tip the back up, and slide it back horizontally.
    Reinstall all hardware with anti-seize hand snug.
    I've got it down to a 30-40min chore every fall including ladder setup
    jetjr likes this.
  18. swags
    swags Moderator
    I really don't have anything to add, these guys nailed it. I do want to say this thread really made me smile though. Every person that commented had great input and showed why this is such a great place. Everyone helped out and showed they cared to improve the learning curve for a new burner. Like others said we all started somewhere and had to learn all of these things, it's great to have a group like this so willing to help.
    basod likes this.
  19. Lil'John
    Lil'John
    I'll say again, thank you for all the input.
    With the top down, I'm just trying to do a little bit of experimenting to help with cold box startup to help minimize looking like a train :whistle: If I was in the middle of a 100 acre lot, I'd probably care less.
    basod likes this.
  20. oldspark
    oldspark
    NW Iowa
    Sorry if I missed it in all these posts but did some one mention that Oak is Not that good for starting a fire, the dense woods dont start so easy, I like Ash, Cherry, Silver Maple or any less dense wood to get it going and then add the Oak.
    Lil'John, basod and swags like this.
