Any reason to muffler mod a 372xp xtorq?
Discussion in 'Chainsaws and Power Equipment' started by J. Dirt, Dec 8, 2017.
  1. Fabz
    Fabz Banned
    Buffalo ny
    You are correct on that muffler - it is stainless steel ... however the 372xp is steel to the best of my knowledge ... my point was u can easily drill em out and enlarge the hole rinse and repeat until you are satisfied with the performance... I suppose you can do the same by brazing it ; heating it to temp and after enlarging hole rebraze ... if concerned about the “longevity” of the aluminum rivers u can braze/weld or use nut/bolt washer and peen thread once you are at the desired opening size ...
  2. huskihl
    huskihl
    I believe instantly
  3. Fabz
    Fabz Banned
    Buffalo ny
    Well my timing light must be off kilter because after machining the key .020 my timing advanced on the 261c to 28degrees ... I’ve run the saw for about 10 tanks and it doesn’t seem to have reset back to the stock setting ... in the interest of the truth I will check it and see if the mtronic challenged it back to stock and report the results
    concretegrazer likes this.
  4. J. Dirt
    J. Dirt
    I’m no expert by any means that’s for sure but I go 5psi acetylene and 20psi oxy with I think #2 welding tip just low and slow. It’s flux coated rod that’s probly 10 years old too :rofl: :lol: I think I got this one a little warm it seemed to flow out pretty far but looking to the inside there’s good filling so it works for me! Kind of fun to play around with. I’ve done a couple other mufflers and they are still together so I guess that’s what counts!:D
  5. huskihl
    huskihl
    I think you're close. You may have been a tiny bit hot or the tip too big, given the width of your braze. But it's pretty dang close
  6. The Wood Wolverine
    Can I do it with a map torch? And the rods I had looked at were flux coated.
    p61 western, J. Dirt and huskihl like this.
  7. Fabz
    Fabz Banned
    Buffalo ny
  8. Redfin
    Redfin
    central Pa
    What light are you using? Mine will not register past around 10k. Last time I heard Scott was also looking for a light that will work correctly where these saws wot.
  9. huskihl
    huskihl
    Probably. The problem is, the braze goes to the red metal. The wider your heat, the wider your braze
    J. Dirt and The Wood Wolverine like this.
  10. The Wood Wolverine
    Great advice, thanks Kevin. Is there a negative to it being wide?
  11. Fabz
    Fabz Banned
    Buffalo ny
    2-stroke timing light for nitro-fuel helicopters ... 17000rpm
  12. huskihl
    huskihl
    It gets thin also
    J. Dirt and concretegrazer like this.
  13. concretegrazer
    concretegrazer
    Southwest MO
    Brand/model?
  14. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Remove about 95% of the flux from the rod with a wire wheel, pliers, knife or other means. It will help you out immensely.
  15. mdavlee
    mdavlee
    Tig welding is how I put all of mine on
  16. J. Dirt
    J. Dirt
    :salute: Not bad for learning back in high school :D
  17. J. Dirt
    J. Dirt
    My next door neighbor is a welder and just bought a Tig set up as his retirement present to himself he said he’d teach me I can’t wait to test it out!
    i notice with all the flux on I have to be able to differentiate between molten flux and bronze while laying it down. Then after I’ve got a bunch of “glass” to chip or brush off especially if I’m going to paint it! Thanks for the tip I’ll give it a rip with a naked rod next time :bug::rofl: :lol:
  18. mdavlee
    mdavlee
    I do it all the time. I've swapped bottles about 4 times at home this year.
    huskihl, J. Dirt and concretegrazer like this.
  19. concretegrazer
    concretegrazer
    Southwest MO
    Been a long time since I tried & failed at brazzin. This was one of my issues. I'll have to retry. Thanks for the tip Fifelaker
    mdavlee, huskihl, p61 western and 2 others like this.
  20. J. Dirt
    J. Dirt
    Last time I did it on my 55 muffler. Got done, hey this looks great painted it then put her to work and a few heat cools later the flux all popped to show my terrible braze
