Any reason to muffler mod a 372xp xtorq?
Discussion in 'Chainsaws and Power Equipment' started by J. Dirt, Dec 8, 2017.
  1. J. Dirt
    J. Dirt
    This is what happens when you are up at 530 29062F59-B0AF-4BB9-A918-1542EED0AFD0.jpeg CEE94F2A-47A6-46A1-99E1-2985BA4D6FC4.jpeg 24C39C9E-587F-4E51-B1A9-42E8C841936B.jpeg
  2. Fabz
    Fabz Banned
    Buffalo ny
  3. The Wood Wolverine
    p61 western and J. Dirt like this.
  4. Fabz
    Fabz Banned
    Buffalo ny
    Gotta use the proper-rod ... any will hold it but you will get a “white dust” after the saw sits for awhile ... let me see if I can find the #
  5. Fabz
    Fabz Banned
    Buffalo ny
    I’m also fond of the pop-rivet technique ... in combo with a 288 husqvarna deflector ... u can start with a 1/2 hole in muffler and enlarge to suit your application ... here’s a 261c with a husky deflector pop-riveted (it’s not a 288 ; next size smaller ) beauty is u can drill the rivets , enlarge hole and rinse and repeat until you find the right size/geometry
  6. Fabz
    Fabz Banned
    Buffalo ny
  7. Fabz
    Fabz Banned
    Buffalo ny
    The 261c REALLY wakes up with this muffler mod ; squish tightened and modified and .020 off the key to slightly advance timing ... I have the equipment to deck the cylinder and mod the muffler for a reasonable fee ... I’ve run this against a few builders ported 261c’s and with a Razer chain I’m right there with em ... with above mods ...if I widened the exhaust and did some “flow enhancements” I believe the saw would be a force to be reckoned with !
  8. dall
    dall
    West Virginia
    i call bs
    and besides the mtronic filing the key to change timing does not effect
    the mtronic will goober the timing back to stock position
  9. The Wood Wolverine
    Haha, someone I have on ignore must be posting... I don't see nuthin!!
  10. Fabz
    Fabz Banned
    Buffalo ny
  11. dall
    dall
    West Virginia
    this is a family site fabz not one for your family reunion pictures
    huskihl likes this.
  12. huskihl
    huskihl
    Looks good on a shelf. Those aluminum rivets won't last long in the real world
    The Wood Wolverine and dall like this.
  13. dall
    dall
    West Virginia
    i bought a rivnut set i thought about doing deflectors with
    huskihl likes this.
  14. huskihl
    huskihl
    Me too. So far so good
  15. Fabz
    Fabz Banned
    Buffalo ny
    Really ? Had em in there for YEARS ... matter of fact the muffler will probably rust away around the rivers as aluminum don’t rust ! Hahaha
  16. concretegrazer
    concretegrazer
    Southwest MO
    Then why does tree monkey do it?
  17. dall
    dall
    West Virginia
    with regular rivets if you drill them out you will be fishing pieces out of the muffler
    concretegrazer likes this.
  18. huskihl
    huskihl
    It's a stainless muffler, so I doubt it'll rust before the rivets fail. Probably ok for an occasional use aaw.
  19. huskihl
    huskihl
    Scott tested it, and with the 261, he found that the mtron will return the timing to factory specs
  20. concretegrazer
    concretegrazer
    Southwest MO
    I must be remembering something else them. Does it do that over time or instantly?
