Any Ideas on this Hanger?
Discussion in 'The Wood Pile' started by Marshel54, Nov 14, 2017.
  1. Timberdog
    Timberdog
    Az
    If you got a good pick em up truck you could get a good long cable hooked up to it at the base and then make a notch on the top of the trunk and cut up all the way through from underneath. Then get in your truck and pull it down. Just make sure your cable/strap/ rope is sufficiently long so you don’t pull it down onto your truck or yourself and you are far enough away. If no truck use a winch after you make the cut to separate it from the rootball. Don’t get under it. Work slow. Work from a distance till it’s on the ground .
  2. Marshel54
    Marshel54
    If my friend says, "we aren't doing this" so be it. It isn't in a traveled area of the woods and no harm. I am comfortable leaving mother nature take her course.
    Backwoods Savage and savemoney like this.
  3. JCMC
    JCMC
    Just outside of Shushan, NY
    Sometimes that is the best option. After all I waited for ten years for the old White Oak to come down.
  4. Backwoods Savage
    Yes. He knows what he is doing and between you two, it will get done.
    HolsatiaRedneck likes this.
