Any Ham Radio Operators on FHC?
Discussion in 'Hobbies and Interests' started by Well Seasoned, Dec 2, 2019.
  1. Eckie
    Eckie
    Gmrs looks good because there's no test, yet it can use repeaters, at least that's how I understand it. The international and other long range contacts does sound like fun, but honestly I don't think I'd have much time to pursue.
    I'm mainly thinking about these comes for emergency purposes, and I know in a true emergency rules and licenses are out the window (to a degree). So thinking gmrs is a way "in" the game, kinda in the middle road.
    Haven't seen an obvious answer to this question on what I've been reading/watching....is there a radio capable of using (receiving and transmitting) all the bands, lawfully)? Or can the all do that if you set them up correctly? To a degree I'm not worried about the lawful part, questioning more about can the radio actually do it, not then"legal to transmit" aspect...
    Oh and I forgot this part. I looked on repeater book and mygmrs, and I don't see any repeaters, on those two sources, near me. Closest shown were probably 20-25 miles away. Anyone have/looked into getting their own small repeater, such as the retevis rt97?
    Chaz and Chazsbetterhalf like this.
  2. Chaz
    Chaz
    Southwestern NY
    Not that I'm aware of. I think in order to get FCC type certification the radio's have to be able to transmit only within authorized bands.
    Some have "general recieve" capabilities, but without modification they won't transmit out of band.
    GMRS.. is definitely an option, the main benefit I see is that "if I remember correctly" the whole family can communicate via the same license.
    Edit.. GMRS can be up to 50 watts, whereas FRS is limited to 5 watts.. Can make a big difference.
    But it might be FRS "Family Radio Service" that covers that.
    Chazsbetterhalf and Eckie like this.
  3. Chaz
    Chaz
    Southwestern NY
  4. Eckie
    Eckie
    Does FRS use repeaters? I know I read that GMRS does, so that would be good, if there are any close enough to hit.
    Chazsbetterhalf and Chaz like this.
  5. Well Seasoned
    Everything would use a repeater, including any radio within distance which is also a repeater
    Chazsbetterhalf, Chaz and Eckie like this.
  6. Chaz
    Chaz
    Southwestern NY
    Not sure about that.. if a repeater requires CTCSS tones, I'm not aware if FRS radios can do that.. I would think that GMRS radios have some implementation of that given what Eckie has mentioned.
    I've not gone in depth on the capabilities of FRS or GMRS radios, so.. I'm not the best one to say yea or nay on this.
  7. Joseph Valenti
    Joseph Valenti
    East Haddam, CT
    No, FRS is simplex only. FRS can use CTCSS.
    GMRS shares some frequencies with FRS and those channels are at reduced power limit channels 8-15. Some GMRS channels are sectioned off as repeater pairs, some as simplex.
    Both are UHF line of sight only.
    I have a GMRS license that I got shortly before getting my amateur radio license. I wanted my wife to be able to contact me in the event of emergency. I had a 50w base station and a pretty good antenna, actually, I’m not sure if I exceeded maximum ERP since it was a 9.1 DBi antenna .
    I never really used it because I ended up passing my general and upgrading to amateur extra immediately and then putting a UHF repeater on the same antenna mount with a similar antenna.
    Also my wife got her technician license, so the GMRS is really only for my brothers and kids to use.
    I should add that GMRS repeaters are not as easy to find as ham repeaters.
    Also with regard to an emergency, the hams will be organized and not stepping on one another while the CB and other services may be crowded and unorganized.
    Jutt and Chazsbetterhalf like this.
  8. wildwest
    Antenna question, is this one I bought a 2M?
    Chazsbetterhalf likes this.
  9. wildwest
    smile.amazon.com/gp/product/B00KC4PWQQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  10. wildwest
  11. wildwest
  12. Chaz
    Chaz
    Southwestern NY
    Yes.. What are you attaching it to?
    The plug connectors are different for some radio's.
  13. wildwest
    Thank you Chaz, it's for a Baofeng, already screwed on :)
    Chaz, Eckie and Chazsbetterhalf like this.
  14. Well Seasoned
    Those nagoyas are decent antennas
    Chazsbetterhalf, Chaz and wildwest like this.
  15. wildwest
    Thank you for chiming in, I didn't want to use up more of your time than I already did :) I bought in 2020 with the Baofeng, and it was likely your suggestion on that too :) I just could never figure out what a 2 Meter antenna was. I thought it was a 6.5' pole :rofl: :lol:
  16. Chaz
    Chaz
    Southwestern NY
    Well, that would be a 2 meter long antenna.
    :yes:
    Not sure about additional benefits from a full wavelength antenna, but it should perform better than the typical 1/4 wavelength vertical.
    But I wouldn't wanna carry it around.
  17. Chaz
    Chaz
    Southwestern NY
    Psshhh.. I've got time I've not even wasted yet.. got plenty to spare.
  18. wildwest
    Oh gosh, thank you so much Chaz, I'm sorry my previous comment came out like it did :emb: I had an on and off pm with him for a couple years now and I know he's been really busy lately. I hope you understand?
  19. wildwest
  20. In the Pines
    In the Pines
    it might be my area but I don't get much reception with my baofeng and that nagoya.
    I can listen in on 911 fire but I can't hear the local FD respond that is 2 miles maybe from my house. Occasionally if the atmosphere is just right
    I can hear the squads but pretty rare. I'm considering getting a telescoping antenna to try and get better 2m reception.
    Thought I read the nagoya are more tuned for the 70cm band??
