Any Excel experts?
Discussion in 'Everything Else (off topic)' started by Gary_602z, Jan 6, 2018.
  1. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Should be simple just hard to explain.
    Setting up a new sheet for 2018 based off the sheet I used for 2017. Just have some formulas that are right but just dont carry down to the next row.
    My first row that has a formula in M2 and N2 work, but when I enter my data into row 3 M3 and N3 don't have the formulas in them. Just need them to advance down as I insert another row.
    Thanks
    Gary
    ( He who doesn't understand Excel)
    Chvymn99 and wildwest like this.
  2. XXL
    XXL
    Ontario, Canada
    Click on the cells with the formulas (M2 and N2), left click on the small black square in the bottom right corner while you drag down as far as you need. Hope this helps.
    or highlight the cells, right click, copy. Highlight the cells you want to pasta to, right click again and paste formula.
  3. Gary_602z
    Gary_602z
    Thanks I will give it a try tomorrow when I get off the road.
    I have a line at the bottom that gives me totals for the different columns. That right now is at row 4 I think. I normally just insert a row and enter my data.So drag the formulas down to that or all the way down the sheet to however many rows I think I will use for the year (Probably 7-8 hundred).
    Thanks
    Gary
  4. wildwest
    It's been several years since I've used it, a version came out at some point with a "paste special" opposed to the normal paste, I think there was a "formula only" choice. No doubt I probably had to go in an manually change the cell range, but it did what I needed. I wonder if Woodwidow uses it at work and knows?
    Gary_602z likes this.
  5. lukem
    Copy and paste the cells you have now to where you want the formulas.... or highlight and drag as described above.
    wildwest and Gary_602z like this.
  6. Woodwidow
    Seems everyone has the right answer, even one that I didn't know about.
    campinspecter and wildwest like this.
  7. eatonpcat
    If I understand the issue, everyone is correct...If you have a cell with the equation that you want, when you copy and paste that cell all the properties will come with it. If this doesn't work, pm me on Monday and I will help get you back on track.
    wildwest and Jack Straw like this.
  8. DNH
    DNH
    Missouri
    And I was hoping someone would be able to explain pivot tables to me!!!:faint:
  9. Woodwidow
    Pivot tables are beyond me. I have a co-worker who is a whiz at them and whenever she sends me an Excel spreadsheet with them in it, I always muck it up.
    campinspecter likes this.
