And so it begins...............
Discussion in 'The Pellet Bag' started by pelletguy, Mar 1, 2016.
  1. Pete Zahria
    Pete Zahria
    New Hampster
    Risk/Gain seems out of whack to me...
    But I'm no investment mogul either...
    :emb:
    Dan
    bogieb, JustWood and IHATEPROPANE like this.
  2. Scot Linkletter
    Scot Linkletter
    Athens, ME
    Testing is done internally. Not every 100 tons because that would be constant testing but probably every 1000.
    The quality of wood used for industrial pellets puts them right around the 1% ash, or slightly over.
    I only mentioned that scenario because I've heard that has happened and a huge mill in the southern US was put out of business. I haven't talked to anyone directly involved so I consider it just a rumor.
    ttdberg, IHATEPROPANE, bogieb and 2 others like this.
  3. JustWood
    JustWood Guest
    Just curious if you might know, but is the testing done at a higher temp than a residential pellet?
    ttdberg, bogieb and IHATEPROPANE like this.
  4. oldspartantrader
    oldspartantrader
    Northern NY
    I believe the Canadian government financed a big chunk of the Trebio start-up in 2010 or 2011. (Read 4 million somewhere last year.)
    A venture capital firm bought a failed pulp operation and the Trebio plant was the poster child to get the whole industrial park off the ground.
  5. Scot Linkletter
    Scot Linkletter
    Athens, ME
    I don't think it's done at a higher temperature. Industrial users usually have an ash fusion temperature requirement also.
    Ash testing is done in a muffle furnace and the burn is done pretty slowly (don't want a fire, just a smoldering burn). Mine does the moisture test at 180°C and then the ash test at 600°C. I'm pretty sure the industrial test is done exactly the same as the test for residential pellets.
    bogieb, ttdberg, artc and 2 others like this.
  6. Scot Linkletter
    Scot Linkletter
    Athens, ME
    Also, European industrial users have some other requirements. They want the pellets to meet the DIN standards. They also might have a particle size distribution requirement.
