Amount of water in green wood
Discussion in 'The Wood Pile' started by Paul bunion, Nov 19, 2013.
  1. dutch
    dutch
    Central NY
    Nice test. :thumbs:
    Do we have a multi variety test we can look forward to watching this year???
    Fanatical1 likes this.
  2. Fanatical1
    Fanatical1
    Very interesting work, and thanks for posting this. It appears oak loses about 40% of its weight when seasoned?
    How do you know that it's bottomed out and won't lose a little more?
    It's amazing how much more quickly you can dry wood out with a little heat. My dad was always convinced his wood stacks that were in full sun seasoned much more quickly than the ones he had top covered next to the garage in the shade. Your posts with the weights over time are appreciated.
    whitey, Chopy and Stinny like this.
  3. MrWhoopee
    MrWhoopee
    Shingletown, CA
    I do appreciate the visual aids. Sort of puts it in terms I can understand.:D
    Sam likes this.
  4. Machria
    Machria
    Long Island, NY
    YOUZA, that's amazing when you calculate it that way. I've noticed my 8' tall green wood stacks, lower about 12" the first year. I guess that's from all that volume loss....
    firecracker_77 likes this.
  5. Machria
    Machria
    Long Island, NY
  6. Well Seasoned
    Nice test PB!
  7. Paul bunion
    Paul bunion
    Its a good possibility. I have a log load on order, will need to see what's on it.
    It has only lost 75 grams since May. Short of baking it dry in the oven it is pretty much done losing weight. I'm not so sure my wife would go for a piece of oak in the oven at 175 for several days.
  8. Paul bunion
    Paul bunion
    Did another one. This is red maple. It was standing green on December 20. It didn't get weighed till the next day but I did keep it frozen till I got to the scale. The starting weight 4482 gm. Current weight 2724 gm and still losing a few gm every day. So after 42 days by the fire the loss is 1758 ml, a little more than the vodka bottle or just short of five 12 oz beers at 355 ml per.
    In pounds 9.9 became 6.
    The first day by the fire accounted for 1/5 of the loss or one beers worth.
    So far it has lost 39.25% of its original weight making it somewhere between 75-85% moisture content when green.
    Pretty close to what I squeezed out of the oak.
    Burn dry wood people.
    whitey, Sam, Drvn4wood and 8 others like this.
  9. mike bayerl
    mike bayerl
    Great thread. Love the practical real world. For more precise calculations, refer to Hoadley, "Understanding Wood." As a wood worker, who takes his wood from tree to final product, it never ceases to amaze me how much water/weight comes out of green wood to kiln dried (~8% MC). Stacking and shuffling green wood vs. k.d. is amazing.
  10. splitoak
    splitoak
    jefferson co wv
  11. firecracker_77
    firecracker_77
    IL
    I want to perform this test with ash. Oak is a tricky animal for sure. She requires patience. I claim that you can get some decent heat in under a year out of ash if you are not that far ahead. I have no real way to prove this other than just results in the stove with good secondaries and no hissing or bubbles from steam. Doesn't mean it wouldn't have been better if 3 years had gone by. :emb:
    Fanatical1, Sam and splitoak like this.
  12. splitoak
    splitoak
    jefferson co wv
    Ya godda do wat ya godda do:yes:
  13. Chopy
    Chopy
    Upstate NY
    Your dad was right it took me 3 years to figure out that stacked north to south in late March or early April dries the wood the quickest without covering it. I know that by getting sun from sun up till sunset makes all the difference as well as good air flow.
    whitey likes this.
  14. Firewood Bandit
    Firewood Bandit
    In late Spring I did an experiment drying wood. Nothing really surprising, but it does put things in perspective. I had two fresh chunk of red oak right off the splitter. I tested the moisture and weighed the two pieces. I then just stuck them in the garage and weighed them yesterday, re-split and tested the moisture again.
    I have always been of the opinion that wood dries faster in open air exposed to the sun. This wood was under my workbench out of the sun.
    The Results:
    April 13,
    Piece #1: weighed 8.5 #'s Moisture was at 25%
    Piece #2: weighed 7 5/8ths #'s, moisture was at 25%
    November 15,
    Piece #1 weighed 6#'s, moisture was at 19%
    Piece #2 weighed 5#'s, moisture was at 16.5-17%
    __________________
    Now just think if you threw those two chunks in the stove green. It would be the same as throwing the same two dry sticks on and then throwing 5 pounds of water on too. 5 #'s of water is over 2 quarts. When burning green wood energy is absorbed to drive off the water as steam. The phase change from water to steam absorbs a lot of energy.
    __________________
  15. markr
    markr
    ohio
    I am such a firewood nerd. I found this very interesting.
    Deacon, Paul bunion and Chopy like this.
  16. Chopy
    Chopy
    Upstate NY
    Then I must be as well.
    Paul bunion likes this.
  17. markr
    markr
    ohio
    I explained it to the dw. Got the deer in headlights look. Then told her she would stay warmer. Ohhhh I understand. Sheesh
    Paul bunion and fox9988 like this.
  18. firecracker_77
    firecracker_77
    IL
    I take it piece #2 was outside?
  19. Firewood Bandit
    Firewood Bandit
    No the pieces were side by side under the bench. #2 had more surface area and was smaller, hence it dried quicker.
  20. firecracker_77
    firecracker_77
    IL
    I would be curious to see the difference at 1 year and 3 years. What I mean is that there is a diminishing return after wood has dried for a period of time. The wood will shed the most moisture in the first year percentage wise. I agree with everyone on here that we should all have so much wood on hand that we don't need to get at the wood too soon. I am very pleased that I'm not in any danger of running out this year for the first time in 5 years.
    Loon likes this.
