Alright! Who has tried this?!
Discussion in 'Chainsaws and Power Equipment' started by LinkedXJ, Apr 30, 2020.
  1. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Smart:dex::rofl: :lol:
  2. Rush Battle
    Rush Battle
    WNC
    This is one of the best threads I’ve seen here! :rofl: :lol:
  3. M2theB
    M2theB
    Central Massachusetts
    2 thoughts
    Use the ram on a rope to the bed to tug and chock and tug again, etc,
    Or flatten the tires on the truck
    Or both
    I suppose that’s 3
    Chazsbetterhalf and Screwloose like this.
  4. Cheepbeer
    Cheepbeer
    NW Ohio
    Simple...back up straight!
  5. Mwalsh9152
    Mwalsh9152
    Pelham NH
    With the gate up like that he would have complete visibility of the splitter going up the ramps. I'd give that a shot. But then again, I've done some F'd up things when it comes to towing in the past.
    You kinda gotta be a little unhinged driving wreckers.
  6. Haftacut
    Haftacut
    Rives Junction, MI
    Glad it worked for you. Little harbor freight winch mounted on a piece of wood behind the wheel wells might not be a bad idea. Maybe a bit more controlled ascent too? Again...glad it worked for you this time.:yes:
  7. zymguy
    zymguy
    Ely MN
    It’s a Jeep thing , I understand stand
  8. jo191145
    jo191145
    Ct
    I would try it. As someone mentioned you can see it pretty well in the rear view mirror.
    My tuck is so high, and I’m short and broken, I often stand outside and fine tune the driving to get my trailer hitched. Saves me from jumping in and out of the cab. Think that’s why they developed back up cams :)
    Screwloose and Chazsbetterhalf like this.
  9. Stinny
    I used my JD, with a trailer ball in the bucket, to roll my splitter up onto a work deck. I'm sure, if I'd tried to back it up, I would have seen a splitter barrel roll before I was done... :whistle::D
  10. brenndatomu
    It'll be a "Jeep" splitter when it pops off that ball and loads itself into the back of the Cherokee! :rofl: :lol:
  11. oldspark
    oldspark
    NW Iowa
    I've done it but a lower pickup backed up to a hill, i pushed it in by hand by myself.
  12. Wes Hightower
    Wes Hightower
    North Carolina
    Not me. I used to load my motorcycles in a pickup truck but would find level ground to roll them straight on/off. My splitter is almost 500 pounds and if it went over not sure how I'd ever get it back on it's wheels alone not mention potential damage.
  13. Husky Man
    Husky Man
    Mt Hood Oregon
    This is what I do when I need to take the splitter with me
    We have a 27 Ton DHT splitter, if the trailer deck is Dry I can pull it up by hand. I have thought about mounting a Harbor Freight 2,500# or 3,500# winch to the front rails of the trailer walls to make it easier, but alas, I am a cheap bastard and have yet to prioritize the Time or Money to do it yet.
    I have a couple of 4’ 2”x12”s and some 6x6” blocks that help ease the slope when I need to, but most the time I just pull it up the ramp and tie her down
    We have piggy backed the splitter in the big trailer wood cutting in the past, I can get about a cord on and still load the splitter. If I push the splitter in, and then unbolt the tongue and stand up the splitter beam, I can get about a cord and a half on, either way makes the trailer balance heavier on the tongue than I would normally load, but my old F350 takes it in stride
    If I want to split and load more than a cord and a half, the Wife has to drive her Expedition to haul the splitter home, and we often go places to cut, that she wouldn’t want to take her car
    Doug :cheers:
  14. jo191145
    jo191145
    Ct
    I see you’ve put some thought into your operation. Ok but I gotta ask. What’s the reason for splitting on top of a trailer?
  15. Stinny
    Working height. Bad lower back for years. Lets me keep all of the work at bench height. Plus... I really like trying ways to fight gravity... ;)
  16. jo191145
    jo191145
    Ct
    I hear ya on the bad back and gravity thing.
    So you split vertical on that platform?
  17. Stinny
    Yep... and the lift brings the rounds right to the biz end of the splitter. Works great but is way too much to set up for a short session. Have thought about rigging the lift in between 2 trees, and rolling the splitter up on a couple car ramps I've got, to get the horiz layout almost at bench height... but all down in the woods. I'll prolly plan to do some planning about a plan... tomorrow... or Thursday... :whistle:
  18. Rope
    Rope
    Alaska
    I had no part in this....but looks normal for these parts.
    Screwloose, MAF143 and Husky Man like this.
  19. mikeward
    mikeward
    Long Island, New York
    I have put splitter in back of my pickup twice and both times found a low spot for truck to sit in. Couple of ramps were only a slight incline to truck. I pulled splitter in by myself trailer ball end first and lowered into corner of bed. Straps locked splitter in place.
    Unloading was interesting. Once was the reverse of loading Using a low spot and worked well. The other was from full height and was difficult. Lots of weight going down ramp now good!
    I modified a small trailer to carry the splitter after this experience. I drilled a hole in the front of trailer metal angle iron and put a trailer ball there. Now I pull splitter up ramp and lock onto ball. What a difference. Only tie down rear of splitter.
    Couldn’t find a pic of splitter On trailer but here’s some with a small trailer mounted. You get the idea.
  20. Ronaldo
    Ronaldo
    The ball fastened to the trailer rail is a great idea! Very secure.
    Sent from my SM-G930VL using Tapatalk
    Screwloose and Husky Man like this.
