Advice Please
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Dec 17, 2016.
  1. yooperdave
    Bingo!
    I can get the secondaries to fire on all three of my stoves.
    But if the stove temp is too low, those secondaries will stop burning within 1/2 hour ish and the draft has to be reopened as the stove;s temp will start it's downward spiral.
    Eric VW and Backwoods Savage like this.
  2. concretegrazer
    concretegrazer
    Southwest MO
    I figured you had & that I was just reading to literal.
    Horkn, Eric VW and Thor like this.
  3. concretegrazer
    concretegrazer
    Southwest MO
    Are you sure that your wood is dry? ;)
    Horkn, Eric VW, Thor and 2 others like this.
  4. bushpilot
    bushpilot
    Eastern Washington
    :picard:
  5. yooperdave
    When I got my first epa stove, yes I was sure it was dry because it burned without problems in my non-epa stove, right? :whistle:
    Sound familiar? :thumbs:
    I went through all the searches and questions of what is wrong with the stove, the venting, the elbows, etc etc! Couldn't be the wood, right? :rofl: :lol:
    After my third year it was burning great; the fourth and fifth year was just icing on the cake! (I'm talking years for the wood pile now)
    Horkn, Thor, Backwoods Savage and 2 others like this.
  6. Eric VW
    Time works wonders on firewood.....the body, on the other hand, not so much.....:BrianK::pain:
  7. oldspark
    oldspark
    NW Iowa
    What kind of wood will effect how far you can turn down the air, Poplar would work better then many of the more dense woods, turning it down to quick as mentioned could muck it up though.
  8. Kimberly
    Kimberly
    The Kangaroo State
    I have had training in the arts as well as the sciences; :D
  9. Kimberly
    Kimberly
    The Kangaroo State
    This is a good point and is where my manual for the Madison differs from the 30-NC. My manual states that 550F is considered a medium to high heat output and that 600F is considered the maximum operating temp and that it should not be done for long periods of time as unit damage can occur. I am still uncertain where to measure STT; they say above the door. I have it on the top of the stop near the edge above the door but I would like a illustration from them.
    Thor and Backwoods Savage like this.
  10. Kimberly
    Kimberly
    The Kangaroo State
    So I need to get the flue hotter before damping the stove down? The flue temp was in the middle of the good range.
  11. oldspark
    oldspark
    NW Iowa
    That is a good question, I reread your first post and it sounds like you shut your stove down all at once which might not be the best way to do it, shutting it down all at once with 550 stove top and in the middle of the good range on the flue might be too much too soon.
  12. Backwoods Savage
    Most generally the hottest part of the stove top is the best place to measure temperature. But it is still a good thing to have an IR gun to take temperature readings in different spots on the stove to find the hottest part. You should be able to borrow one of these gadgets if you can't afford one.
    mike bayerl and Thor like this.
  13. Kimberly
    Kimberly
    The Kangaroo State
    Yes, there may be hotter areas of the stove. However, the manual stated to measure temperature with a magnetic thermometer above the door on either the left or right side. Now there is no room above the door on the face so I have it on the top of the stove. I am going to ask the manufacture to provide an illustration for where they mean to place the thermometer.
  14. Backwoods Savage
    Kimberly, I'm guessing that they did mean the stove top, above the door and not the side of the stove above the door.
    Eric VW, Kimberly, Thor and 1 other person like this.
  15. Eric VW
    I concur.
    Kimberly, use your scientific training and measure and record temperature readings by moving the mag therm to several spots. USE A HEARTH GLOVE TO MOVE THE THERMO.
    You can manually build a data log in less than an hour. And if you don't like the results, throw the log on the fire!:rofl: :lol:
  16. Kimberly
    Kimberly
    The Kangaroo State
    Why do I want to take the time to create a thermal gradient map of the stove top? What would the purpose be other than just information of where the stove gets the hottest during operation? The manufacturer has stated where to measure the stove temperature for operation. Let's say that I find a spot that gets 700F during operation; that is of no real concern if the point where the manufacture states to take the measurement is at normal temperature for safe operation. Without an inferred thermometer it would take too much time; since the magnetic ones are slower to respond. Still, an inferred thermometer is something I would like to have so I can monitor my frying pan to keep the temperature below the smoke point of the oil I like to use. At the moment I use visual inspection; "Yep, it is starting to smoke."
    mike bayerl and Backwoods Savage like this.
  17. oldspark
    oldspark
    NW Iowa
    The infrared testers are great as you can check temps on your electrical system for hot spots.
    Backwoods Savage and Eric VW like this.
  18. bushpilot
    bushpilot
    Eastern Washington
    If more precise placement were needed, I think they would have stated so. Just go for the hottest spot.
  19. Eric VW
    For the sake of "owning" your stove and the useful empirical information a wood stove owner operator/owner can glean from their equipment.
    Your logic about "time" spent is at odds with owning a moisture meter. You could have simply waited 1-3 years depending on species, but you opted to buy and use the MM- an effort which logs your wood's MC, and the time to gather that info.
    Difference? I see them as two canned brands of soup....they're both soup, and regardless of ingredients and flavor, you still open them the same way, heat and eat....you have to cook them for such a time, prepare the bowl and spoon, gather your crackers or toast......
    I'm only suggesting you put your meticulous nature to some useful end regarding the operation of your stove, because you know as well as any of us, the manufacturer's response will most likely not suite your inquiry.
    Merry Christmas :salute:
  20. Kimberly
    Kimberly
    The Kangaroo State
    Actually I brought the meter because I did not have a stash of wood; it was important to know if the wood I had on hand was safe to burn.
