Advice on smallerish tractor for the woods
Discussion in 'Chainsaws and Power Equipment' started by basod, Dec 29, 2016.
  1. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Pushing or pulling weight is your friend. Definitely want loaded tires on it. Hills and tractors don't mix well!
    Gary
  2. Gasifier
    +1 Keep that loaded bucket close to the ground. Lower center of gravity = safer. :thumbs:
    clemsonfor and Woodsnwoods like this.
  3. basod
    basod
    Mount Cheaha AL
    lawns....
    where we're going we need no lawns....
  4. Gasifier
    :salute: That is why I am considering an Agricultural tractor this time as well. (If I can sell the 210C I have.) I would be able to get one with R1 tires, a removable backhoe, and a loader with quick attach bucket. Some of the loaders are quick attach as well. Not just the bucket comes off, but the whole loader comes off quick. Nice. Especially if you want to go through the woods with a brush hog behind you and not feel like your driving a train with the loader out the front as well.:D
  5. cnice_37
    cnice_37
    What you want to lift with the FEL and how long you want to spend digging with the backhoe will figure out your tractor size range and then go from there.
    There are always deals to be had with cash in hand and willing to travel.
    The B21 would be my upgrade (B2100) but the backhoes on these machines are tiny and not worth the expense over renting on occasion or hiring out.
    I have a 42"? bucket and spin a 4' blower or drag a 4' box blade. Very capable machine, certainly not moving pallets of firewood, but makes my life easier.
  6. Eric VW
    I wonder what Dascro can add to this topic?:)
  7. 94BULLITT
    94BULLITT
    Frederick County, VA
    If I was buying a tractor for working in the woods I would want a tractor the at least the size of an L series Kubota. Subcompact or B series is a little small for a woods tractor. Hydro tractors are more user friendly than gear. 3 range hydros are better than two. Look for a tractor that has a removable loader in case you want to take it off. It also makes working on the tractor easier. A quick attach on the loader is a must so you can change out attachments in under a minute. Do you really have much use for a backhoe? You can rent a mini ex that is more productive every year or two for those jobs. Depending on your budget I would not rule out looking at a new tractor.
  8. 94BULLITT
    94BULLITT
    You sure about that;)
  9. MasterMech
    Just a few thoughts to add from a guy who sold a few of these. (New/used and green/yellow)
    Digging stumps of any significant size (8"+?) is not an easy task for a small machine. I'm sure Gasifier can attest to how big a fight a modest stump can put up for even a full size TLB like his 210.
    Those 0% finance deals, especially the long term ones, usually cost the dealer a significant chunk up front in a "user fee" or "finance fee". This fee is normally passed on to the customer via either declaring it on the invoice or more commonly by inflating the sale price.
  10. concretegrazer
    concretegrazer
    Southwest MO
    Depreciation is also being held in check thanks to tier 4 engines. And all the other new tech that makes it harder for us to work on them.
  11. 94BULLITT
    94BULLITT
    The price for my BX was the same cash or financed. The only difference for cash was there was a $1000 rebate from Kubota. I think the L had a $1500 rebate at the time. I have heard of people financing longer that what is advertised for 0% but a dealer said they just add it to the cost of the tractor. On a Kubota or JD the best way to be sure you are being treated fairly is to build the tractor on their website the way you want it. A good deal is 18% off. A average deal is 10% off.
  12. 94BULLITT
    94BULLITT
    Some larger older tractors (mostly Deere) are appreciating. I think some or worth more now than what they cost new 25 years ago.
    It is illegal for a farmer to work on his on new tractor. Farmers Demand Right to Fix Their Own Dang Tractors - Modern Farmer
  13. concretegrazer
    concretegrazer
    Southwest MO
    Like this?
    Used Construction, Agricultural Equip., Trucks, Trailers & more
    Paid 63 for a new one just like it in 02. Mine just doesn't have the 3rd rear scv.
    And the software crap is just dumb. There won't be any new ones here for as long as that is in place.
  14. 94BULLITT
    94BULLITT
    Great example!
    Compacts are getting up close to $60k now.
    Sent from my SPH-L710 using Tapatalk
    Woodsnwoods likes this.
  15. MasterMech
    I can't speak for other brands but I know Deere adjusts the MSRP % over dealer invoice depending on the series. A 3038E and 3x20 series compact had VERY different "advertised" margins. This is common throughout the industry really. Certain "price sensitive" models meet their price point partly due to a tightened profit margin. Stihl did it, quite often. Despite being near identical machines, an MS290 would have a much thinner margin than the next model up, the MS310. MS170 vs the 180, etc.
    Sometimes it's tough to know if you are getting the shaft or not, as dealers can work their sales invoices differently. One may include everything in the stated price and others may break out and show you their prep fees and delivery costs line by line. It's much harder to discern how much the dealer is making when everything is lumped into one price. Compact Utility Tractors in particular are a time consuming prep, especially if there are lots of options and attachments that need to be assembled, mounted, plumbed and wired. Older Gators (6x4 and 4x2 prior to the T series models) were next in line as EVERY option had to have a wiring harness installed through the unibody/frame or be hand-wired. We jumped for joy when they introduced the HPX and T series with modular wiring harnesses that made adding lights and dump kits a plug and play ordeal.
  16. Gasifier
    I have pulled many over the years. Stumps can be very difficult, I try to take my time and break all the roots all the way around and then work my way in trying to twist the stump out by using leverage of bucket against ground to loosen it up.
    Because of this I am hoping to rent a track-hoe/excavator in the 17 ton range for a week to do a lot of stump pulling on the logging trails when I can afford it. But unfortunately I spent too much money on the barn.:doh::(
  17. basod
    basod
    Mount Cheaha AL
    I've run several smaller machines you realize pretty quick a loader on most of them is nothing more than a glorified loose material bucket. That's why I'd want a hoe especially in the shale and clay down here. I know it's not going to dig stumps like a trackhoe at least have the ability to scratch up some fill when needed and I'm planning for septic repairs
  18. fox9988
    fox9988
    NW Arkansas 72717
    [​IMG] I'd suggest a 4wd for any smaller tractor with a loader. With any weight on the front (forks or bucket), especially on a grade, they are helpless in 2wd. Granted mines usually overloaded.
  19. mike bayerl
    mike bayerl
    I'm a total non-expert, but I was able to pick up a used L3710 this sprintg and absolutely love it. Personally, I wouldn't want to take a B/BX in my woods, too hilly and rocky. The only downside so far is no SSQA on the FEL. I plan to fix that this Spring. I agree totally with MasterMech and Gasifier. Must be 4WD, Hydro, and if new SSQA. SSQA and extra hydro line can be added later an are not terribly expensive if you can find a great used one. BTW, did you take a look at the Kioti' s. We have a great dealer here so I was looking at them, when I found my Kubota that had just been traded in for a bigger Kioti.
  20. lukem
    I don't own a tractor, but I've spent plenty of time on them over the years. You never want to be under-tractored (too small, too light, not enough lift). It will make jobs take twice as long as they should, if you can even do them at all. Woods tractors need to be pretty short to make the tight turns, light enough to not sink down in the loam (check local listings), and have plenty of ground clearance. Anything other than ag tires in the woods and you are cheating yourself traction-wise.
    My favorite tractor is my dad's old massey (same as a 9N). It is nimble but has (just) enough guts to haul big logs out of the woods. I'm not saying this is the right tractor, but it is the perfect size and weight. I used to run a Kubota L series on occaision. It was a touch smaller, but with 4wd there wasn't a lot it couldn't do as far as getting stuff done in the woods.
    I'd go 30HP, 4WD, ag tires, pick a color you like.
