Advice on smallerish tractor for the woods
Discussion in 'Chainsaws and Power Equipment' started by basod, Dec 29, 2016.
  1. mike bayerl
    mike bayerl
    Again, I'm no expert, but the L is build on a sturdier and heavier frame with generally higher capacities for everything (FEL, 3-pt, etc.) Someone who knows better could give you more details.
  2. clemsonfor
    I was wondering about this?
    Woodsnwoods likes this.
  3. mike bayerl
    mike bayerl
    Oops, a little late on this. Already covered.
  4. 94BULLITT
    94BULLITT
    Frederick County, VA
    More flow on the hydraulics. The tractor is longer and wider. Larger tires.
  5. cnice_37
    cnice_37
    B is like a WR, L is more like a TE.
    How's that?
    basod, Chvymn99 and 94BULLITT like this.
  6. 94BULLITT
    94BULLITT
    Also in the L series there is the Standard L and there is the Grand L. The Grand L is a deluxe tractor. It also has more lift capacity on the FEL and 3PH. An L3240 or 3540 would be a very nice tractor for you.
    basod, Chvymn99 and Gasifier like this.
  7. nosurprise87
    nosurprise87
    The B2650 looks like a good middle weight contender in the orange corner.
    Sent from my XT1650 using Tapatalk
    basod, 94BULLITT and Chvymn99 like this.
  8. MasterMech
    Large frame compacts rock! I remember the first Deere 4720 I got to play with.... 60hp was quite surprising in that little package.
    Gasifier and 94BULLITT like this.
  9. basod
    basod
    Mount Cheaha AL
    Great as long as the TE doesn't break down every season:p
    Chvymn99 and cnice_37 like this.
  10. cnice_37
    cnice_37
    Don't remind me :picard:
    clemsonfor, Chvymn99 and basod like this.
  11. Gasifier
    I was going to tell you of a B26 on e-bay, but it's gone already!:picard:I am sorry. I didn't think it would go that fast. He ended auction early, like after a day or less. Someone got a deal. :picard:It had a grapple, thumb on hoe, rake.:doh: These are real working machines for smallerish tractors.
  12. Gasifier
    94BULLITT likes this.
  13. 94BULLITT
    94BULLITT
    The B2650 is not enough power to be under the tier IV emissions. So it it does not have a dpf. I'm pretty sure it has the same engine as the old B2920 so it probably would be easy to get 29hp out of it.
    Sent from my GT-P3113 using Tapatalk
    nosurprise87 likes this.
  14. basod
    basod
    Mount Cheaha AL
    I was wondering what the cutoff was in HP range the EPA website I thought stated all transportable diesel engines movable under their own power were subject to the tier 4?
    We ran into a similar CF years back under tier I/II when buying an air compressor at work and literally had to add it to the plant's air permit -even the folks at ADEM thought it was foolish
    Gasifier likes this.
  15. basod
    basod
    Mount Cheaha AL
    I think the rule for NOx emissions is for 56kW/75HP and Particulate PM emissions 19kW/25.5hp
    clemsonfor and 94BULLITT like this.
  16. 94BULLITT
    94BULLITT
    I think you are right with 25.5hp.
  17. nosurprise87
    nosurprise87
    Kinda like Mahindra did with the Max 28. The same engine is in the 26. I think they are rating them at a lower rpm to be under tier IV emissions. When you say easy to get the 29hp do you think it's in a tune or a re-flash or is there a throttle stop or something or maybe something as simple as running it wide open on a stock tune? Makes me think this is one of those "Volkswagen" deals.
  18. 94BULLITT
    94BULLITT
    I just looked the 2920 was rated at 2800RPMs and the 2650 is rated at 2500rpm. I thought they might have made a couple tweaks to the injection pump to reduce power. I bet everything is the same.
  19. nosurprise87
    nosurprise87
    It's plausible that everything is the same. Like you said though it could be in the fuel mapping.
  20. DNH
    DNH
    Missouri
