Advice needed
Discussion in 'Chainsaws and Power Equipment' started by colby severson, Aug 26, 2014.
  1. reckless
    reckless
    Keep in mind you need to buy a gallon of bar oil, 2-cycle mix and a gas can if you dont have one for premix gas...... oh and gas lol good luck bud and cut safe!!
    HDRock likes this.
  2. Grizzly Adam
    Grizzly Adam Guest
    Chainsaw chaps at cheap at Menards too. I wouldn't cut without them or hearing protection. I use $10 Winchester muff style from the Walmart hunting section.
    reckless likes this.
  3. reckless
    reckless
    I have the same for when Im not felling otherwise helmet and screen. +1 on the chaps!! Especially if you're cutting on the ground!!
  4. Jon1270
    Jon1270
    Pittsburgh, PA
    I think an inexpensive new saw is the way to go unless you either have some experience with small engines or want to make a hobby of working on them. A lot of craigslist sellers either don't understand the problems their saws have or misrepresent them, and most set their prices higher than the saws are worth.
  5. DexterDay
    DexterDay Administrator
    Northeast Oh
    Welcome to FHC Colby!!
    If you stick around here long enough, you will have a half dozen (at least) saws and more wood than you can shake a stick at :axe:
    Everyone will think your crazy! ! :loco: :crazy: Except us :)
    Keep us posted on the saw, and as others stated, wear your PPE. Chaps, Hearing protection, and safety glasses are items you should have before starting to cut.
  6. mm3alan
    mm3alan
    Bettendorf, IA
    Has anyone replaced the cylinder and piston kit in a John Deere (EFCO) CS52? Mine is scorched from some bad gas, but an otherwise good saw with low hours.
  7. Jon1270
    Jon1270
    Pittsburgh, PA
    Welcome to the forum! It might be better to start a new thread for your question.
  8. GRIZ
    GRIZ
    Stihl :popcorn: from the new borns to the old mens:drool::drool::rofl: :lol::rofl: :lol:
    Chvymn99 likes this.
  9. HDRock
  10. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    You may want to have a look at the FHC classifieds. Lots of folks selling good stuff.
    HDRock, MasterMech, Chvymn99 and 2 others like this.
  11. colby severson
    colby severson
    Mason City, IA
    Is there a real big difference between getting the 18 and the 20?
  12. Jon1270
    Jon1270
    Pittsburgh, PA
    It's not very clear what you're asking. What 18 and 20 do you mean?
  13. nate
    nate Banned
    Palmer, AK
    18" isn't as common. It's what I run. I have a 32 or 34" bar if I need to cut big stuff, but I've never had to use it.
  14. Oliver1655
    Oliver1655
    Central Missouri
    Difference between the Poulan 5020 & the 4218.
    - The first 2 numbers is the size of the engine, 50cc vs 42cc.
    - The second 2 numbers are the bar length.
    As you will be whittling down larger pieces, I would go for the 5020. The bigger engine will be nicer.
    Word of caution, the bar studs are set in the plastic. Snug the bar nuts but do not try to get them "real" tight. If you over tighten them they will distort the plastic.
  15. colby severson
    colby severson
    Mason City, IA
    These two were recommended and are what i was thinking about getting when i have enough after bills to go get. I just didn't know the real difference between the two.
    Thank you for the explanation Oliver. Once I am able to get the chainsaw might have someone explain more in detail about what you mean by bar nuts. (complete newbie when it comes to anything but starting a small chainsaw and doing very small cutting of 6x6 landscape timbers)
    Grizzly Adam likes this.
  16. Grizzly Adam
    Grizzly Adam Guest
    Get the bigger saw, otherwise you will kick yourself afterwards. Bar nuts are just nuts that hold the bar on, don't over tighten them.
    Oliver1655, HDRock and colby severson like this.
  17. colby severson
    colby severson
    Mason City, IA
    easy enough.
  18. HDRock
    Really, if I were you I would go for the refurbished 5020 I linked to on eBay at 140 bucks, it will save you about 70 bucks over buying it locally retail, but if you wait too long those deals will be gone.
    Once you get the saw come back and everyone will help you with all the little details :)
    Jon1270 likes this.
  19. colby severson
    colby severson
    Mason City, IA
    i would if money wasn't so tight at the moment. will have to see tomorrow if i have left over of my paycheck
    HDRock likes this.
  20. colby severson
    colby severson
    Mason City, IA
    side note, nice thing is my father dropped off a pallet of scrap construction wood (he owns a lumber yard) so I have a nice pile of wood to use for now for my few fires that I do have.
