Advice for sore elbows?
Discussion in 'Everything Else (off topic)' started by Easy Livin' 3000, Mar 25, 2020.
  1. Easy Livin' 3000
    Easy Livin' 3000
    North side of the ridge
    I had a similar thought. I do think the enteric coating helps it get through the stomach before dissolving, so...
  2. brenndatomu
    Yes, just gets it past the stomach...
  3. The Wood Wolverine
    So folks, last Saturday I had a copper compression sleeve delivered and have had it on 24/7. My left elbow was pretty sore from the time I brought home that last load of oak. Only took it off for showers/baths. I would say the copper has zero effect to this point. It still isn't 100%. Moved the wood March 24th.
    I was skeptical to be honest but I wanted compression sleeves and these fit the bill (I've since bought another one for my right side). The compression does fell good but the copper aspect, IMO, is a gimmick. If I had it to do over again, #1 I would have noodled the big rounds and #2, I would have bought something that restricts movement a little more.
    Easy Livin' 3000 and Jack Straw like this.
  4. Easy Livin' 3000
    Easy Livin' 3000
    Thank you for trying it out and your honest review.
  5. dgeesaman
    dgeesaman
    Elizabethtown, PA
    This kind of tendonitis appears in my elbows pretty easily. I have to take it very easily and not try to lift/move anything too heavy with one hand - especially to not twist or maneuver it while I'm holding it. Easier said than done when moving / handling firewood.
    Prednisone will wipe out tendonitis quickly but it's not good for you. I find it takes months for it to clear on its own. I have to baby it.
    I can also aggravate my elbow by using a mouse and having my mousepad a little too high. Something I am recently reminded of using my work-from-home setup.
    David
