Advantage of using plunge cut to fell
Discussion in 'The Wood Pile' started by Marshel54, Oct 22, 2019.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I'm with Dennis on this one. I only use a bore cut for difficult fellings. I've learned a few different notch cuts, including the Humboldt, and use them as conditions require. But sometimes a bore cut is the safest solution to a problem tree.
    tamarack, bear 1998, jo191145 and 5 others like this.
  2. Horkn
    Lol. I know better. Go Lumberjacks!
    Yes, that's a real picture from a Humboldt State game.
    tamarack, Marvin, bear 1998 and 6 others like this.
  3. MrWhoopee
    MrWhoopee
    Shingletown, CA
    Somebody had to do it.
    I saw them opening for Aerosmith at Cal-Expo. There was a chain on the saw, he cut up the stool he was sitting on at the end.
    huskihl, Marvin, Thor and 3 others like this.
  4. jo191145
    jo191145
    Ct
    I’m with Dennis too. Heavy leaner ok it’s the best way to go. Everything else is old school.
    I see no pluses in using it to fell a tree in the opposite direction it naturally wants to fall. Your trigger is now where the greatest leverage for the wedge is. Your making it harder on yourself and cutting up your wedges in the process.
  5. Flamestead
    Flamestead
    Windsor County, VT
    I use it heavily. I’m mostly thinning in pole timber, and want to minimize collateral damage, plus I love the control.
  6. Yawner
    Yawner
    Louisiana
    What about doing a plunge cut with a Humboldt notch, do you start the plunge to establish the hinge right behind the top cut?
  7. buZZsaw BRAD
    I never knew it had a name. I use it mostly now on my fellings for the same reason. In most cases ill cutoff the stump after.
