Adding Humidity
Discussion in 'Everything Else (off topic)' started by firecracker_77, Dec 13, 2013.
  1. MasterMech
    We had a steamer on top of the stove for awhile. Was waaaaay more trouble than it was worth. Didn't seem to do jack diddly other than spew little balls of sediment everywhere when we let it boil dry. :mad: Plus moving to a top-loading stove made an easy argument to ditch the pot. Bought a real humidifier and never looked back. The wife tossed the old steamer on my scrap metal load this summer. :)
  2. Grizzly Adam
    Grizzly Adam Guest
    We've had the mirrors in the bathroom fog up when we are refilling the kettle regularly.
  3. charlie
    charlie
    Schoharie, NY
    I see you have what looks to be a Country stove... I had one 20 years ago, S210 model... What a great stove! Easy to run and put out lots of heat... Fan was super quiet too... We left it in the house when we sold.. I thinking the guy is still using the stove that he has wood piles in the yard when we drive by once and a while..
  4. H 2 H
    H 2 H
    It was bought in 91 I just put a new gasket in it every other year along with new bricks and it's as good as new
    It takes about a cord a month which isn't bad and it runs 24/7
    charlie and firecracker_77 like this.
  5. HDRock
    I have a nice porcelain teapot I was using it heated up very quickly but it just wasn't cutting it .
    When it got down to 16 percent I started boiling water on the kitchen stove , got a humidifier now and it keeps it around 30 percent
  6. charlie
    charlie
    Schoharie, NY
    It was the sole heater in our home years ago... We never used the furnace.. We use to burn about 3 cords a winter..
    H 2 H likes this.
  7. defiant
    defiant
    Old Lyme, CT
    I use a large kettle on wood stove and have a germ free slant fin humidifier near the pellet stove, on these cold dry days I am able to only maintain 30%, then I supplement with a pot of water on the gas range.
  8. firecracker_77
    firecracker_77
    IL
  9. Locust Post
  10. firecracker_77
    firecracker_77
    IL
    Sure thing...the only thing that makes me nervous is the filter. I don't want an ongoing maintenance expense.
  11. MasterMech
    I have a similar unit, I change the wicks/filter out 1X a year. Get them online, MUCH cheaper than in stores.
  12. Grizzly Adam
    Grizzly Adam Guest
    Been rendering fats the last couple days in addition to the usual humidifier, I almost need a dehumidifier.
    Scotty Overkill likes this.
  13. Huntindog1
    Huntindog1
    South Central Indiana
    I use a whole house humidifier and it makes my heat in my house much more effective at heating my house and making it comfortable heat. Moisture in the air will cut down on your colds you get. As if you dry out your throat and sinus's you expose yourself to irritation and that will cause you to get infections more easily. For years I told my parents about this but they never took it serious but the spent thousands on trips to the doc for antibiotics. Finally I just bought them a humidifier and gave it to them and when the number of sinus infections were greatly reduced they jumped on board so much they went and bought one room humidifiers to run right next to their beds. As they are elderly and sleep in separate rooms now.
  14. HDRock
  15. firecracker_77
    firecracker_77
    IL
    And is it easy to maintain humidity levels with 8 gallons? I would think that's more than enough.
  16. HDRock
    Yeah ,works good I only have 1200sqft
  17. charlie
    charlie
    Schoharie, NY
    This is the only way I could see getting around filters.. Had the ultra sonic ones, discs that heat the water use to scale over, warm mist didn't seem to so very much.
  18. MasterMech
    When I was a kid, we had an old Kenmore Rotobelt type humidifier. Huge capacity. Do they still make that type of machine?
  19. WeldrDave
    I keep an old cast iron dutch oven and a steam dragon, "fitting" on top of the old Grandma, seems to do a good job, it keeps about 60% humidity in the house. Got lucky when I found the dutch oven, in a flea market for $5.00, "SOLD" ;)
  20. My IS heats my home
    My IS heats my home
    Albany, NH
    Totally agree with huntindog's last comment. +1
    I just refilled our 'whole' house humidifier, it still takes 6 gals/day and runs nearly 24 hrs per fill.
    even though the homes humidity is generally around 24% , it does make a difference.
    no more nose bleeds and no more major skin dryness
    WeldrDave likes this.
