Absolute Steel Hybrid
Discussion in 'Modern EPA Stoves and Fireplaces' started by Flamestead, Jan 23, 2016.
  1. HarvestMan
    HarvestMan
    Southeastern Michigan
    We have hardly heard any beta results yet and already listed for sale ... that was fast. Was it this fast for the PH and IS releases?
    Keweenaw and Backwoods Savage like this.
  2. Backwoods Savage
    I'm not sure why several folks are put off by the wings but it is not a problem anyway as you can order the stove without the wings. They give the stove more design but not everyone is interested in this.
    What point is trying to be proven? First and foremost is to market a different sized stove than the IS was as not everyone needs the heat of the IS or Progress and the ASH is just a bit larger than the Fireview. Also Tom keeps trying new ideas and thanks to him for doing this.
    In addition, one big point is the emissions. The Race to Zero (or as close as one can get). Tom is committed to producing a stove that really burns cleanly because there are so many areas where problems exist with other stoves. It has to be nice trying to be a leader in new stove technology. There are many others working on this problem and hopefully some day they can get wood burning super clean so there are not problems with burning wood.
    burndatwood, Doug and Keweenaw like this.
  3. Keweenaw
    Keweenaw
    tapiola mi
    Does Woodstock run a sale like this yearly? Or is this a one shot deal to get prices like this?
  4. Backwoods Savage
    Yes, typically there is some kind of sale going on although the sale prices may vary a bit. If I remember right when we bought there was free shipping for the stove but don't recall what the final price was.
    Keweenaw likes this.
  5. Flamestead
    Flamestead
    Windsor County, VT
    It feels quicker. Of course the IS was their first steel stove, and this is a variation on that design, as opposed to a completely new direction. I think the IS was out to beta testers before the EPA tests, and this one is out after them, so that might explain some of the difference. The PH had several changes after the initial release (we have three different tops for it, for example); I'm not sure what they did for testing for it before it went on sale.
  6. JA600L
    JA600L
    Lancaster, Pa
    Are you getting any consistent burn times yet?
  7. Flamestead
    Flamestead
    Windsor County, VT
    I've been hesitant to say much because I'm feeling a bit disjointed by other events and not too focused on operating the stove efficiently. Plus my daughter is home and adding a few pieces during the daytime while we are away at work, so we aren't getting a good feel yet for how it will perform for our usual routine.
    Overnight burns have been fine - we have plenty of coals in the morning (similar to the IS, we sometimes have too many coals, and spend time burning them down so there is more room for wood on the reload). I think it burns more like the IS than the PH - the primary airflow isn't as strong for burning down coals.
    I have not been able to visibly see effects from the air inlets at the back of the firebox. The IS lower inlets were very noticeable, and the PH central inlet has a visible jet at times during most burns.
  8. Woody Stover
    Woody Stover
    Southern IN
    Now that I've seen actual pics of it with the design, the wings look OK to me. One of the chairs I sit in is way off to the side of the stove, so I still might be inclined to get it without wings so it would be a little easier to see the fire when I'm ramping up a new load, I don't know.
    Flamestead, can you measure from the bottom of the ash pan to the floor? I know that they offer a 2" reduced height version, but I still need and additional inch or so to get under my lintel, which is around 28.5". Also, I'm guessing the legs are welded to the box, not bolted? If that's the case, I guess I could special-order the stove, specifying the leg length I needed, rather than cutting the legs myself...
  9. HarvestMan
    HarvestMan
    Not likely based on my research. Legs shorter than what the stove is tested for invalidates the certification. I too was hoping for the same center line as the keystone, fireview, and PH (short legs), but seems like shortest center line is going to be 26.5.
    papadave likes this.
  10. Flamestead
    Flamestead
    Windsor County, VT
    About 3.5" from the bottom of the ash pan to the floor. However, the ashpan door handle, when closed, is 2" off the floor. Even as-is, when the door is open its handle hits the floor and the door is laying out flat (level). They would need to double-check that the pan could come in and out with the legs shorter.
    This reminds me of the crazy, non-approved install I grew up with; top vent, then turned 180 degrees to lose some height, then 90 degrees to horizontal into the thimble. As I've learned on these forums, I'm surprised I'm still alive (green wood, clay tile liners filled with creosote, little respect for clearances, etc, etc).
  11. Flamestead
    Flamestead
    Windsor County, VT
    We just reloaded this morning and ran about 5 minutes with it open, closed the bypass, and then several minutes later moved the air control from wide-open (4.5 on the scale) to 2. That killed the flames. A check outside shows no smoke. Woodstock is closing the bypass even sooner into the reloads - the cat seems to be very responsive, we'll have to see how that lasts as we get a few more miles on it.
    Now about 5 minutes more, and the STT is 450, flue 400, and lazy flames lifting off the logs at the front of the firebox, and a little bit of secondaries. Too cold out to shoot for a cat-only burn (10 degrees right now). My wife's plan of action is to leave as-is unless the STT continues to climb (my plan of action is to leave for the desk job. sigh.)
    Well Seasoned and Brad38 like this.
  12. OhioStihl
    OhioStihl
    Southern Ohio
    There isn't that much of a price difference between the IS and Absolute. If I was going to buy one I would be tempted to go big. Obviously dimensions and preference on looks are a factor but having the potential to go big in a total power outage or major cold snap is nice.
    Just to clarify on prices, I like the Great Plain version of the Absolute and the black IS with ash pan and soapstone liner.
    freeburn likes this.
  13. Oldhippie
    Oldhippie
    Ashby Ma
    No.
  14. Flamestead
    Flamestead
    Windsor County, VT
    After I left for work, my wife noted that at
    8:20am it was STT 550 and flue at 475. She moved the control down to 1.5. The firebox reacted with a lot of strong rolling secondaries. She wrote "it was really sucking air".
    8:30 STT 570, flue at 400, calm secondaries
    8:45 STT 520, flue 360, light secondaries
    Then she left. My daughter reloaded at noon, with STT 300.
    We are trying to be better at logging in a notebook. The weather is warm for this time of year (well, 10 degrees overnight, but up to 40 today).
    We are expecting a visit from Woodstock tomorrow to check the stove and leave some toys. I'll get some pics.
  15. mike bayerl
    mike bayerl
    Dang, 2.5 cu. ft. is about perfect for our house. We have a 2.0 cu. ft. PE Alderlea, and we get a solid 8 hours of heat, but on the coldest nights, and when we want to sleep in, or at least stay snuggled up in bed (doing what men and women do in bed :whistle:) for longer, we have to fall back on the oil heat. It seems like a 2.5 firebox would be the perfect size for us.
  16. Flamestead
    Flamestead
    Windsor County, VT
    This evening's load, so far:
    6:40pm Reload 75% of firebox. Air set to wide open
    6:45 STT 300 flue 300 Bypass closed, air wide open
    6:55 STT 325 flue 375 Bright flames, air moved down to 3
    7:00 STT 375 flue 390 Primary and secondaries burning.
    7:10 STT 400 flue 400 Adjusted air to 2, firebox went black.
    7:20 STT 450 flue 375 Firebox black
    7:35 STT 540 flue 425 Firebox black, shroud around cat is glowing
    7:40 STT 560 flue 475 Moved air to 1.75 (trying to bring flue temp down)
    7:45 STT 575 flue 475 Secondaries light and tertiary light
    7:50 STT 540 flue 400 Secondary and tertiary
    8:00 STT 500 flue 350 Secondaries
    8:10 STT 480 flue 350 Light secondaries
    Tertiary flames? On the front edge of the top of the firebox there are a series of holes for the third air supply. In the fuzzy photo below you can see the strong secondaries in the middle of the pic, and then an upper flame. The upper flame is the tertiary air burning as it head back toward the cat.
    Gark, Doug, milleo and 1 other person like this.
  17. T-Stew
    T-Stew
    I'm not sure if I like the 'wings' or not myself, it is a different look. I'm sure if I had one in front of me it would be different. But it is nice it is an option. Kind of like the Ideal Steel, many comments are about how folks don't like all the fancy artwork. Well you actually have to pay extra for that so if you don't like it you certainly don't have to get it! I think the IS doesn't look too bad just plain black with no options whatsoever. Some other stove companies might offer a choice of a few colors but Woodstock really is unique in offering such a wide assortment of colors and also custom design elements. Would be nice though to get a nicer finish like porcelain enamel, of course that would cost considerably more.
  18. Flamestead
    Flamestead
    Windsor County, VT
    Toys installed, but now off to work...
    No fire lit yet...
    Small fire...
    papadave, Doug, milleo and 3 others like this.
  19. HarvestMan
    HarvestMan
    Where did the draft meter come from? Also, when you get a chance can you explain how you intend to use it in conjunction with the installed key damper in your setup?
    Thanks.
  20. Flamestead
    Flamestead
    Windsor County, VT
    Woodstock is letting me use the draft meter. The range of "normal" (typical) draft is -0.05 to -0.07 inches of water column, and without the damper we are running at least twice as high. With the key damper fully closed it runs at -0.10, so still high. So we've quantified what we knew - it is a strong draft. I think the most valuable piece from this so far is that the fully-closed position is still more than adequate. Beyond that, I'm in new territory for this setup.
    This flue is 32', 6" liner, insulated, in an internal chimney, and little for trees around the house.
