A new year and a new march. 2025
Discussion in 'The Wood Pile' started by jrider, Feb 6, 2025.
  1. jrider
    jrider
  2. showrguy
    showrguy
    Marysville, Pa.
    Sure..
    Those cages are called Cattle panels @ Tractor Supply 50” x 16’, bend em around, overlap by 1 square, fasten together with 3-4 wire ties, string, ect.
    That makes a 5’ circle that’ll sit overtop of a skid (wire to the ground)..
    The wood comes off the splitter into cage, slightly mounded each one holds 1/2 cord.
    If ya wrap em like I/we did, you can solar kiln the wood for the customer that needs truly DRY WOOD. Or just top cover..
    To unload, simply pick it up, get it into/over dump trailer/truck, cut the wire ties, shake a bit, done !!
    It takes alot of handling time outa the process,, and you know time is money.
    In my case, I move em with a John Deere 410 backhoe w/forks, once the wood comes off the splitter I never have to touch it again till it’s time to go into the stove..
    Hope that helps a little ??
    Chuck
    Edit, btw, those panels are about 32 bucks currently..
    John D, Chud, jrider and 3 others like this.
  3. brenndatomu
    Geez, it wasn't very long ago those were $16 on sale, $20 normally.
    John D, Chud, RCBS and 2 others like this.
  4. buZZsaw BRAD
    As well as most other consumer goods!:picard:
    John D, T.Jeff Veal and eatonpcat like this.
  5. showrguy
    showrguy
    Marysville, Pa.
    Yea, I know..
    A few months ago they were @ 42 bucks..
  6. jrider
    jrider
    How are you getting a 5' circle on a pallet? Are these oversized? I typically get/see 40"x48" or something close to it.
  7. showrguy
    showrguy
    Marysville, Pa.
    Nooooo, the pallet sets inside the 5’ circle, so when ya pick it up you gotta hold of both.. make sence ?
    It’s easier to cut out a few verticle pieces of wire with bolt cutters then to be so precise with fork locations when moving them..
  8. jrider
    jrider
    Gotcha
