A little muffler mod on my 555 this afternoon.
Discussion in 'Chainsaws and Power Equipment' started by WVhunter, Jun 10, 2014.
  1. DexterDay
    DexterDay Administrator
    Northeast Oh
    On a stock saw.. Yes. On a ported saw that is making more power and has more pressure on the bearings, crank, rod, etc? I will use the extra ounce of oil. Think about how miniscule of an amount that is, compared to a gallon.
    All equipment used to be 25:1 - 32:1 until several years ago. The EPA is the reason it's leaned out.
    I run 36:1 using my Ratio-Rite cup. :) No smoke, better ring seal as stated above, and my saws look oily when opened up.
    A 50:1 saw will look dry inside of the muffler. Not enough oil for my liking.
    You can also use a lower rated octane level. 93 isn't necessarily better for the saw. Remember, the higher the octane rating, the higher the auto ignition point is (meaning it takes longer or hotter Temps to ignite). Lower octane fuel has a lower ignition temperature (not to be confused with its flash point. Gasoline in general has a very low flash point)
    This is probably gonna open up a can of worms ;)
    I should start a poll. I think the general concensus is to run higher octane. But it is not needed at all. 87 is just fine and will not "dirty" your engine or make less power.
  2. splitoak
    splitoak
    jefferson co wv
  3. Hedgerow
    Hedgerow
    SW Missouri
    Correct... 87 will actually make more power in a saw...
    MasterMech, DexterDay and mdavlee like this.
  4. splitoak
    splitoak
    jefferson co wv
    Why would 87 make more power than 93?..stihl and husky motors are def high performance motors..conventional wisdom says more octan in hp motors....i thought higher octane helped the motor run cooler??..arrrgh:headbang:
  5. Hedgerow
    Hedgerow
    SW Missouri
    Not enough compression in a chainsaw to really get the good benefits from a higher octane...
    It's a mechanical compression thing... Even with 87, the fuel and oil mixture is not done burning by the time the exhaust opens... To short of a duration...
    The big benefit of the premium fuels is, many of them "Not all" are ethanol free... Now THAT's a real benefit...
    clemsonfor, MasterMech and mdavlee like this.
  6. cnice_37
    cnice_37
    I dont know, when I just bought my 346xp it was definitely pinging with 87 and a fresh mix. 93 and no problems and I havent switched back.
    Could have been luck or something else....
  7. splitoak
    splitoak
    jefferson co wv
    Soo..87 ethanol free is better than 10 percent93?
    mdavlee likes this.
  8. Hedgerow
    Hedgerow
    SW Missouri
    Yes...
    Wish I could get it here...
    Only ethanol free available around here is 91, so that's what I use...
    rookie1, concretegrazer and mdavlee like this.
  9. Hedgerow
    Hedgerow
    SW Missouri
    I've run saws with 225 pounds of comp on 87... No pre-detonation...
    cnice_37 likes this.
  10. mdavlee
    mdavlee
    I can get all 3 grades of ethanol felree and most of the time I use 87 since its freshest. I've had a few saws in the 220-230 lbs of compression nd no problems with 87 even milling.
  11. Hedgerow
    Hedgerow
    SW Missouri
    Scott had been running a 361 with 260 lbs of comp on 87 non eth...
    Still running to my knowlege...
    clemsonfor, cnice_37 and mdavlee like this.
  12. mdavlee
    mdavlee
    He was the one that convinced me that it wouldn't hurt one.
    Hedgerow likes this.
  13. cnice_37
    cnice_37
    Ok, I'll try it again. You guys are much more experienced than me.
    Pinging can't be cured by anything other than octane and timing.... Right? Not like a tweak on the carb was in order.
    Do realize, I bought that 346xp after I fried my 351 and found AS for help. I heard "buy a 346xp" and since then the saws have come and gone to the tune of 20 or so. I also was just learning to tune.
    DexterDay likes this.
  14. WVhunter
    WVhunter
    Mountains of WV
    Well dang, I am going back to 87 then. Lol....
    DexterDay and cnice_37 like this.
  15. DexterDay
    Northeast Oh
    Yep. The "High" octane in ways may be worse.
    Higher octane in a chainsaw isn't what it's cracked up to be. As you seen Hedge and Mdavlee talk about above.
    87 is always fresh. A small mom and pop place may sit on 93 for a long time. And if it is a 10% Ethanol mix?? After sitting for an extended period of time, ethanol fuel absorbs more moisture/water.
    Run what you want. I don't push anyone to run 87 or run a thicker oil mix. But people need to be informed of the pros and cons to using a high/low octane fuel and a high/low oil mix.
    mdavlee, Chvymn99 and WVhunter like this.
  16. MasterMech
    So long as your saw is still exactly as Stihl engineered it, 50:1 will not blow it up. But many of us have added power in one way or another and know that 50:1 is marginal. More oil will contribute to better ring seal and make more power in addition to better lubrication and cushioning of shock loads in the bottom end. And today's modern synthetics will not increase carbon build-up within the engine. Quite the opposite actually.
    One engine builder put it this way, "it's not the piston seizing in the bore that worries me (with 50:1), it's the bearings in the bottom end."
    concretegrazer, Hedgerow and WVhunter like this.
  17. Hedgerow
    Hedgerow
    SW Missouri
    Agreed...
    Bad tune and a dull chain killed more saws than 50:1 Stihl ultra blend ever did...
    But personally , I run 32:1...
    Cause I'm paranoid...
    clemsonfor and mdavlee like this.
  18. MasterMech
    You guys are all way ahead of me on this one.... Lol.
    "Premium" fuel usually isn't...... Engines run their best on the very minimum octane required to stop detonation/pre-ignition.
    The exception is if you live in an area where premium is ethanol free, then by all means go that route as it's worth a bunch more power than the miniscule amount lost to the excessive octane rating.
  19. DexterDay
    Northeast Oh
    Amen..
    mdavlee likes this.
