A gifted husqvarna 350
Discussion in 'Chainsaws and Power Equipment' started by WeldrDave, Mar 31, 2020.
  1. The Wood Wolverine
    Bout the only thing IMO that would kill the saw is when the muffler bolts come loose and the hot exhaust melts the case. Aside from that, anything can be fixed.
    One of the first things I do with these is remove those 4 underside riser base screws one at a time and loctite them. Second is metal intake boot clamp and third is a modified 346 muffler bracket.
    T.Jeff Veal, M2theB and MikeInMa like this.
  2. buZZsaw BRAD
    Its in good hands. The chain saw whisperer. Mike's know how is amazing. He has worked on my 020, 026 Stihls, my 335 Husky, my friends 262 Husky as well.
  3. M2theB
    M2theB
    Central Massachusetts
    tank is starting to melt but not through on the sides. Hopefully we can stop that.
    Ever use AM cylinder on these. I never have great luck with AM cylinders. Often need to wallow out bolt holes to everything centered.
  4. M2theB
    M2theB
    a lot of transfer from the piston. I was hoping that long stretch in the upper left was a heavy deposit.
    Unfortunately not. This one has some gouges.
  5. The Wood Wolverine
    I’d much rather get used OEM. AM is just not worth it. I’ve seen so many guys post vids showing the lack of quality, plating peeling/flaking, poor casting etc. I’ve worked over quite a few scored cylinders and it takes a deep gouge to ruin em.
  6. The Wood Wolverine
    That looks bad. Post a WTB on ope and I’ll bet someone has an oem cylinder laying around.
  7. M2theB
    M2theB
    This one has a good one
    Good idea!
    edit: done!
  8. isaaccarlson
    isaaccarlson
    Colfax, WI
    My 350 was burned up pretty good by the previous owner, and the shop I got it from didn't do it any favors. Nothing was tight and there was silicone everywhere, including inside the spark plug. Not sure what cylinder they used. I ordered an aftermarket from hls and the screws were stripped, so it went back.
    I ported the cylinder that was on it and it didnt run right. Leak at the pto seal. Put it back together with more sealer, same thing. Leak in the same place. Tore it down, ordered a new case, leak fixed. The right side had gotten so hot when it burned up that the case was melted/deformed just enough to not seal.
    Now it runs great. I have ported several 350's over the years and have not had any trouble with muffler bolts. I torque them and they stay.
    I think the high temps of a non modded muffler contribute to bolt stretch and then they vibrate out, because all my mufflers have been modded and problem free.
  9. M2theB
    M2theB
    piston and cylinder on the way
  10. The Wood Wolverine
    Couple guys over there had issues with Loctite 518 on plastic case stuff. What kind of sealant do you use? I've been using motoseal for a long time w/ 100% success.
    M2theB likes this.
  11. M2theB
    M2theB
    good to know
    Kevin turned me on to motoseal a couple years ago.
  12. M2theB
    M2theB
    957D3249-5E14-4320-9187-6A117FDE0480.jpeg 5B4DE54F-CEF8-4212-8DBE-F968A3F182BD.jpeg A8E603AD-36CA-4286-9B72-F1163FEF75F0.jpeg 3ABE6E2C-F229-4865-BAC5-2D1923AD7D86.jpeg B11DAB57-4BC1-4122-8E62-37167ECF208B.jpeg 98385D8C-BD52-4765-A3F4-95F00A121B5D.jpeg BD454B2D-815A-4D95-AAE5-A3CD0F944875.jpeg
    Going to take care of the air leaks before worrying about the carb
    Will need to go to the bone yard for muffler bolts. As WeldrDave posted earlier, the original cylinder was re tapped for the big bolts.
  13. M2theB
    M2theB
    May need a little fine tuning and the chain tightened.
  14. The Wood Wolverine
    Sounds/looks good to me. :thumbs:
  15. MikeInMa
    He put humpty dumpy back together!! :salute:
  16. MikeInMa
    The 350 of many hands and miles, is once again back with me. I picked it up this morning from M2theB. I didn't want it to take up space unnecessarily.
    No new pics of it....yet. Not sure when I'll fire it up. When I do, there'll be pics.
    Thanks again Mike. Your efforts are appreciated, as always.
  17. MikeInMa
    I finally got around to giving the saw a good test.
    I'd say it performed very well.
    Red oak.
    Other pics over at Today's victim
    Once again, thanks to WeldrDave for the saw and to M2theB for his time and expertise.
  18. WeldrDave
    I'm glad to see it up and running! :yes: Nice job to all for keeping her going Mike, and M2theB for his expertise! :cool:
  19. buZZsaw BRAD
    M2theB...the saw whisperer! Way to get it done guys! :thumbs:
  20. The Wood Wolverine
    Pretty good test of that saw too. That's big wood for a smallish homeowner saw to be slicing up.
    First saw I ever bought was a Husky 450. Getting serious into hoarding, I realized it wasn't what I would need for the long term. After getting into saws more, had I got a 350 instead, my opinion wouldn't have been the same. I think the older tech is a better piece. I love these saws. :saw: Hope it continues to serve you well. I have no doubt it will with M2theB wrenching on it. :dremel::cheers:
