A fix for tires that go flat
Discussion in 'Chainsaws and Power Equipment' started by Yawner, Jul 27, 2022.
  1. The Wood Wolverine
    Not funny. I've had that sh1t bomb me twice.
    PSA:
    If you do use it, and take the wheel somewhere for someone else to change, please give that poor sucker a heads up. :(
  2. Canadian border VT
    ^^^. This same with fix a flat
  3. brenndatomu
    X2!!! I hate that surprise!
    Hate Fix A Flat too...
  4. Yawner
    Yawner
    Louisiana
    For those who say to warn a tire repair guy about having used any tire repair goo... what will he do different? And why wouldn't he always just assume a tire had goo in it if it's such a problem that he needs to be warned? Just curious. I bought all of my stuff with motors on it as used equipment, I have no idea what previous owners did.
  5. The Wood Wolverine
    If you go real slow with the removal process, 90% of the goo can be kept in the tire. If you have no idea and you’re banging away, BAM! :headbang:
    Same with balance beads, which I use. Tiny little round glass beads that 99% can be kept in the tire if I go nice and slow.
  6. Horkn
    Exactly why I said low speed non street applications. :cool:
    Also, that seems like an excessive amount of slime. I've never had to use an amount that equated to that mess.
  7. Horkn
    Worse with fix a flat. Way worse
  8. In the Pines
    In the Pines
    forgot about project farm doing a youtube video on fixing flats, he tested several products, slime was one, I think he tested plugs also in that video.
    as far as a heads up, it helps the guy breaking it down just to take it slower so it doesn't go all over them. It's still a mess though.
  9. Softwood
    Softwood
    Central WI
    When I bought my Husqvarna mower the manual advised to put a 'slime' type product in the tires right away..
  10. old iron
    old iron
    sw va
    I have had great results using Pepsi cola to seal slow leaks, I use 8 oz in lawn mowers tires works great
  11. brenndatomu
    Interesting...but I'd be hesitant to put a liquid that has a PH of roughly 2.5 (acidic) all over my wheels though...that and my luck would be that the tire would still leak/ooze goo and now every ant in the county would be lined up around my garage! :hair:
  12. MasterMech
    My favorite fix for constant tire issues is buying quality tires. There are a LOT of cases, especially in NHS (non-highway service) applications, where the OEM tire is the lowest acceptable quality to get the job done. Ever notice that you run over all kinds of crap with your tractor, your car, your pickup, your semi, etc. and you don't have nearly the same amount of trouble as you do with your @#$%^& lawn mower? :sherlock::rofl: :lol: Replacing cheap single or even 2-ply turf tires with 4-ply versions (if available) can go a LONG ways in easing the frustration.
    Tubes are asking for trouble in low-pressure NHS drive tires. As noted in other posts above, these tires normally shift position on the rim and this stresses the valve stem area of the tube. Often, the stem tears out or if you're lucky, just pulls back inside the rim. Also, the stem is often a poor fit at the access hole in the wheel, so it's a matter of WHEN, not IF, dirt and moisture gets in there to abrade the tube/wheel and encourage rust that much faster. Keep in mind that if the tire isn't resilient enough to fend off minor punctures, neither is the tube. So if new punctures are a common frustration, tubes are likely to just add to your trouble. (See first paragraph for recommended fix. ;) )
    Now that I've tied myself to the stake, and before y'all light the kindling :MM: - hear me out. Tubes are a good solution for low-value, light duty applications. Your wheel-barrow tire, hand-trucks, indoor equipment, maybe the fronts on a 2WD tractor only used occasionally. But for applications where time = money, and the equipment must be reliable, I can't recommend tubes in the majority of cases. Tire dry rotted? Your only prolonging the inevitable. Damaged? C'mon...., Wheel/bead leaks? If it's bad enough to let air out with a good tire mounted, it's bad enough to let water/dirt (sand) IN when there's no internal pressure keeping it out.
    On high-torque drives - ZTR's, Ag tractors, etc. - There are many "permanent" sealants that work well for minor to moderate tread punctures. Slime is technically temporary (5 years IIRC?) but it will depend on how long it takes you to wear out the tire when determining if it's right for you. When loading larger tires, it was pretty common to load the tire with ballast and top it off with a sealant to prevent the sudden loss of ballast from losing pressure. (Which happens faster on a liquid filled tire.)
    EDIT: TL|DR Tires can be shot with 95% of the tread left on them.
    JimBear, Horkn and brenndatomu like this.
  13. MasterMech
    Have you sprayed soapy water on the troublesome tire? Find out for sure where it's leaking from. Tread? Sidewall? Rim/Bead? Valve Stem? What kind of tire does the Gator have? Some of them are thin (like the turf tires on the 6x4 and 4x2 gators) and they are super low-pressure (5-10 psi). Over-inflating them makes them even MORE susceptible to punctures too. (Same thing is true for most ATV tires.)
    Again with the soapy water. For the fronts, I really like the flat-free foam tires. Expensive up front, but there is no better solution. If they are old and dry-rotted, I'd get new ones, as they aren't usually expensive. Pre-treat them with a sealant.
    All of this ranting and rambling :BrianK: to say - Don't go throwing good money after bad (tires). :emptywallet:
  14. old iron
    old iron
    sw va
    I have used it in tires on my hay teder and lawn mowers for years with no rust out or ants
  15. TurboDiesel
    Makes me let air out faster...:fart:
