93 Octane Gas - No Corn Liquor Added
Discussion in 'Chainsaws and Power Equipment' started by lukem, Apr 24, 2014.
  1. concretegrazer
    concretegrazer
    Southwest MO
    They sell non E in Iowa? I figured it would all be E85.:rofl: :lol:
    Stinny, mdavlee and Pallet Pete like this.
  2. mdavlee
    mdavlee
    Non E is pretty convenient for me. I don't run any E 10 except the wifes vehicle.
  3. lukem
    Keep the old one...it will dry out and fit fine again after a while...and the new one will probably do the same thing. You almost have to rotate them.
    MasterMech likes this.
  4. clemsonfor
    [quoIe="lukem, post: 91496, member: 57"]Keep the old one...it will dry out and fit fine again after a while...and the new one will probably do the same thing. You almost have to rotate them.[/quote]
    But I dont run Ethanol fuel?
  5. lukem
    Are you sure? Sounds like you do if your cap is swelling up.
    MasterMech and Pallet Pete like this.
  6. tuneighty
    tuneighty
    South Central PA
    I was paying 4.21/Gallon when the station near us had ethanol free. Saved in the long run as I only had to fill up once per week. With E10 I was filling up almost 2 times per week.
    Shame they shut down, nowhere near has it now. I try to run a few tanks of the Ethanol free mix in the OPE.
    Corn was made for drinkin, not drivin!
  7. clemsonfor
    [quote="lukem, post: 91517, member: 57I ]Are you sure? Sounds like you do if your cap is swelling up.[/quote]
    But that was the way the cap was when i bought the "$20 poulan". I have no idea what he used. I use real fuel. I promise. Unless I'm getting scammed at the pump.
    Pallet Pete likes this.
  8. Pallet Pete
    Pallet Pete Moderator
    Ovid
    My Poulans have all been the same and I run 110 leaded race fuel no ethanol. Its just a bad design is all.
    clemsonfor likes this.
  9. clemsonfor
    What is the OPE??
  10. reelcrzy
    reelcrzy
    Plymouth MA.
    Yup.. Need channel locks on my Poulan. Thanks for info
  11. NortheastAl
    NortheastAl
    Putnam County NY
    We only get the E10 garbage here. In my two stroke blower and chainsaw I use the quart bottles of 93. Expensive, but hey start, run and work better, I think. If you have an airport nearby you can get 105 octane airplane fuel. By law it can't have Ethanol in it because it freezes when it absorbs water.
    There are a few ways to deEthanol your gasoline which involve adding water, shaking then draining the water from the bottom of the tank. Ethanol is a powerful cleaner. When the gas is fresh you will never get sludge in your fuel system. It gums up when old and has absorbed water. Ethanol fuel lasts about six months without stabilizer.
  12. DexterDay
    DexterDay Administrator
    Northeast Oh
    Outside Power Equipment.
    I believe MasterMech answered that on the previous page.
  13. clemsonfor
    I went back and looked and i didnt see any mention of it by mastermech?
    But thanks for the translation.
  14. MasterMech
    Removing the ethanol from gasoline will lower the octane rating substantially. I'm no chemist but adding water to the fuel (are you ever really sure you removed all of the water/ethanol combination afterwards?) seems just a little more risky than using the stuff as is. ;)
    I've talked to a couple guys that deliver to gas stations and they say that since E10 became universal around here, residual water levels in every station's holding tanks have dropped substantially.
    If you know your fuel has Ethanol in it, and you take steps to deal with it, there is no reason you can't enjoy reliable service from your equipment for years to come. It's all in the proper storage habits and maintaining a reasonable supply so that you are not storing fuel for months at a time.
  15. oldspark
    oldspark
    NW Iowa
    There are some blindly in the E gas boat but many stations sell the regular gas, I like giving the stations that only sell E gas a hard time.
  16. oldspark
    oldspark
    NW Iowa
    Is that state wide, have you checked the web site that shows where non E gas is sold?
    http://pure-gas.org/?stateprov=NY
    NortheastAl likes this.
  17. MasterMech
    This
    If you have 2 or 3 caps (IIRC they are dirt cheap) you can rotate them. One in the machine, one drying out, and one good to go. And people say Stihl's flippy caps are complicated! :rofl: :lol:
  18. oldspark
    oldspark
    NW Iowa
    "I've talked to a couple guys that deliver to gas stations and they say that since E10 became universal around here, residual water levels in every station's holding tanks have dropped substantially"
    No doubt given the nature of the beast.
  19. MasterMech
    Just for kicks guys, check out my location on that map. (Pine Bush NY or 12566) It's like a no man's land for E-Free fuel. Closest one is about an hour and a half drive. :(
    NortheastAl and clemsonfor like this.
  20. NortheastAl
    NortheastAl
    Putnam County NY
    Last I checked no one anywhere near me was selling it. I'll look again.
