7900 experiment
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Sep 8, 2014.
  1. CNE deer
    CNE deer
    ohio
    OK i'm a older gear head how can you adjust timing on a 2 stroke, base gaskets or coil or both??
    clemsonfor likes this.
  2. Hedgerow
    Hedgerow
    SW Missouri
    Ignition timing? Or port timing?
    Cut4fun and clemsonfor like this.
  3. CNE deer
    CNE deer
    ohio
    Ok how can you alter port timing, no valves so to speak of?? Do you egg the holes out of the coil or do they make a offset ?
  4. mdavlee
    mdavlee
    Rotate the flywheel on the crank.
    clemsonfor and CNE deer like this.
  5. MasterMech
    Port timing is adjusted by raising or lowering the cylinder with machine work. spacers or removing gaskets, changing the height of the ports (removing material from the top or bottom), or altering/installing a different piston. Often a combination of methods is used.
  6. clemsonfor
    Or like mike said grinding off the key and reclocking the flywheel.
    I get how they do it in theory is all. I am a newbie and really lay person when talking all this stuff.
  7. Hedgerow
    Hedgerow
    SW Missouri
    Yeah... And sometimes we just sorta pokem' with a stick, and put em back together, hoping for the best...
  8. Cut4fun
    Cut4fun
    OHIO Redneck
    Can do it by just shaving on the oem piston too. Bottom of intake skirt etc. For those on a budget gain. :whistle:
  9. Hedgerow
    Hedgerow
    SW Missouri
    Or a file to the edge of the crown where the transfers open... :whistle:
    That's very Redneck of you Kevin...
    :drunk:
    clemsonfor and mdavlee like this.
  10. Cut4fun
    Cut4fun
    OHIO Redneck
    That too. I actually had that in my post then edited it out. ;)
    clemsonfor, Hedgerow and mdavlee like this.
  11. mdavlee
    mdavlee
    That's the easy way to do it before grinding a jug.
    clemsonfor and Hedgerow like this.
  12. Hedgerow
    Hedgerow
    SW Missouri
    What's a grinder?
    :coffee:
  13. concretegrazer
    concretegrazer
    Southwest MO
    :dremel:
  14. chris
    chris
    SE WI
    Definition of Grinder- a machine that sucks whatever is in your hand out of it a flinging it in some weird direction while simultaneously removing finger nails and finger prints. It can also be used to test the sensitivity to heat of ones fingers.
    Chvymn99, mdavlee and Hedgerow like this.
  15. mdavlee
    mdavlee
    FYI a 390 boot makes it harder to fit the air filter and choke linkage.
    Hedgerow likes this.
  16. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Actually have seen both of those methods used by none other than Husqvarna on race motorcycles. Crude but sometimes the quickest most cost effective method. I would not trust extensive use of it on the cast pistons we have in saws. Perhaps on billet racing pistons.
  17. Hedgerow
    Hedgerow
    SW Missouri
    Cheap and dirty...
  18. Cut4fun
    Cut4fun
    OHIO Redneck
    Several well known shops out west use the trim the skirt method. So it must be ok for chainsaw pistons. :handshake:
  19. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    I did not know that. Thanks for posting that info. I wonder if there are limits to what you can do before you have to mess with the ports. Obviously short circuit is a governing factor.
    DexterDay likes this.
