7900 experiment
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Sep 8, 2014.
  1. mdavlee
    mdavlee
    I never mentioned squish being .035". The saw with the spacer was .021" and stock with gasket was .027".
    cgraham1 and SquareFile like this.
  2. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    You are correct Mike you did not mention 0.035, I must have gotten that from another thread. My mistake! So did you just use custom spacer and 1194 or a gasket to get to 0.021?
  3. mdavlee
    mdavlee
    Spacer and 2 oem gaskets.
  4. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    The fiber ones or the metalized gaskets? I also noticed that the spacer looked to be from 110 annealed copper shim stock.
  5. mdavlee
    mdavlee
    It was one of each. What I had on hand. I used carbon sheet metal. I cut one out of flashing also for .007" but didn't need it after all.
  6. Cut4fun
    Cut4fun
    OHIO Redneck
    First one to figure this out was Ed Heard EHP IMO. He drilled bigger holes across. Others followed suit after that.
    I'll try and dig up the EHP muffler from 07-08 time frame.
    mdavlee likes this.
  7. Cut4fun
    Cut4fun
    OHIO Redneck
  8. cgraham1
    cgraham1
    Nor Cal
    Looks quiet. :thumbs:
    mdavlee likes this.
  9. clemsonfor
    :eek::eek::eek:o_O
    Oliver1655 and mdavlee like this.
  10. cgraham1
    cgraham1
    Nor Cal
    Could you just cut the squish band instead of using the spacer? Or would that put your ports too low?
    mdavlee and DexterDay like this.
  11. Hedgerow
    Hedgerow
    SW Missouri
    There was some reasoning behind the spacer...
    And it did have to do with the port timing and returning to stock if need be..
    Oliver1655, mdavlee, cgraham1 and 2 others like this.
  12. mdavlee
    mdavlee
    You could but that would take a whole lot more grinding to get it to fit. This way didn't change port timing hardly any except intake.
  13. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    If you put enough thought into achieving something, there is ALWAYS a simpler way to achieve the end goal. In this case it was more performance with little or no costly risk. Says a WHOLE bunch for Mike's talent and knowledge. Mike has one, and even Evans said there is more to be had from a Solo 665 but chose not to do it!
  14. mdavlee
    mdavlee
    I haven't ruled out working on my 665. Just not sure I want to do it to it when I have a 7900 on the way.
  15. Stihl bro
    Stihl bro
    Nice thread here fella!
  16. mdavlee
    mdavlee
    Thanks buddy
    SquareFile likes this.
  17. DexterDay
    DexterDay Administrator
    Northeast Oh
    Welcome to FHC Stihl Bro!! :thumbs:
    Chvymn99, mdavlee and cgraham1 like this.
  18. Stihl bro
    Stihl bro
    Thank you DexterDay.
  19. Hedgerow
    Hedgerow
    SW Missouri
    In Pecan...
    "Like Hickory"
  20. DexterDay
    Northeast Oh
    Man that saw sounds Nasty!! :dex:
