70cc's... why did I wait so long?
Discussion in 'Chainsaws and Power Equipment' started by basod, Aug 27, 2014.
  1. cory@owen
    cory@owen
    I'm sure they were. I hear those are one of the best saws to port. Seems all the 300 series are.
  2. MasterMech
    You are going to become highly attached to that saw. They make great all-day worksaws!
    splitoak likes this.
  3. MasterMech
    The 441C-M is a fantastic candidate for porting as well. Mine is a monster at "only" 71cc.....
    splitoak, concretegrazer and Chvymn99 like this.
  4. cory@owen
    cory@owen
    I'd love chance to run one someday. And all the other stihl saws for that matter. I just don't know anybody that has one. I would snatch up an 044/440 if I found a deal on one. Those stihl saws just don't depreciate.
    clemsonfor and Chvymn99 like this.
  5. MasterMech
    I don't know where you are located or where you roam but you're welcome to run mine if we ever meet.
  6. mdavlee
    mdavlee
    A good 044/440 is hard to beat for a light weight 70 cc. They're a tiny bit lighter than a 372 even with 3/4 or full wraps.
    concretegrazer and clemsonfor like this.
  7. cory@owen
    cory@owen
    If I find myself up your way I'll make sure to bother you a little, but it's a long haul from Ga.
    clemsonfor likes this.
  8. cory@owen
    cory@owen
    Take a day off work and bring both of them to the Mid Ga GTG. Let me try ' m both.
    concretegrazer likes this.
  9. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Mike as you already know, there is a way to put a 7900 jug on the 665 but I have been promised two Solo 681 C/P kits out of Germany. I have also been told by Randy that the new slab sided pistons work better than the windowed ones originally speced out by Solo. So we may be able to work something out.
    concretegrazer, Chvymn99 and mdavlee like this.
  10. cnice_37
    cnice_37
    You could have got the OP's saw with "free" shipping!
    Check the classifieds here. KRL had a sweet one for you that would have kept you in orange, and brand new.
  11. mdavlee
    mdavlee
    From what it sounds like the newer 7900 kits are the same. They moved the decomp up on the top right. I haven't bought one to see for sure. They come with a new top cover.
  12. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Yes, but the 7900 kits are not (to my knowledge) set up for the 1mm stroked crank. You cannot take some material off the squish band to cure that situation, because IMHO doing so will throw the port timing way off.
  13. mdavlee
    mdavlee
    I'm not worried about that part. A spacer will fix that. I don't think I'd take that much out of the chamber any way. The compression would be a bit high for those cranks to handle I would think. I could pull it out and weld it but would prefer not to.
  14. MasterMech
    Why not? It's not something one would normally disassemble and it's a known Achilles heel on these saws. I know you have the skills and the equipment. :) Or would you just rather not split the saw?
    mdavlee likes this.
  15. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Splitting the case is cake. The HVA tool for a 372 will do it.
    mdavlee likes this.
  16. Chvymn99
    I know if I try to pull that on that saw with the decompression, my body will suffer. Its got pretty good compression..Has any body check it yet with a gauge?
    mdavlee likes this.
  17. DexterDay
    DexterDay Administrator
    Northeast Oh
    I didn't know you got the 441!!
    As MM said, that is a great saw! And a huge step up from an 041!!
    A port job isn't necessary. But man is it one saw that benefits from it!!
    This thread evolved fast!! :dex:
    splitoak and basod like this.
  18. mdavlee
    mdavlee
    If you're not going all out on it I don't think its needed. A nice woods port type it should be OK for no more use than I can put on one with all the saws I have around. The port timing would be fine with a little grinding here and there.
  19. mdavlee
    mdavlee
    The 665 has 175 or so after one tank.
    clemsonfor, DexterDay and Chvymn99 like this.
  20. clemsonfor
    Yep when I run a 70cc saw I have a :D on my face. I like big saws so much i usually run the ms650 which is an 84cc saw!!
