562xp intake, problem??
Discussion in 'Chainsaws and Power Equipment' started by Sandhillbilly, Sep 22, 2019.
  1. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Does anyone else get a layer of really fine oily sawdust in the intake horn on their 562 husky? I’m not sure it’s causing any trouble (yet) but it’s always there when I pull the filter. And it can’t be doing the engine any favors. I put a really thin o-ring in the groove on the filter but it was an old and kinda hard one. That made the keeper clip really tight but didn’t really stop it. Any ideas ????
    bear 1998 likes this.
  2. GrJfer
    GrJfer
    The Woods of Arkansas
    One of the knock on of the 562xp. The new filter system on the 572xp is supposed to be much improved. I put a thin layer of grease around the base, and it seems to help. Your other option is a high stack filer.
    bear 1998 and tamarack like this.
  3. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Haven't noticed it on mine, yet.
  4. Ronaldo
    Ronaldo
    This issue has been discussed on other sites and the general consensus is that the very fine particles that manage to get in don't do any harm as they are so small and fine. I certainly don't, however, like the idea of anything getting through the filter media or around the base, etc. I have a 555 and I have put a thin layer of grease around the base AND a small bead of grease between the upper and lower halves of the two piece filter. The area where the filter halves snap together is where the fines were getting through on mine. A little grease fixed the issue on mine.
    Andyshine77 and bear 1998 like this.
  5. huskihl
    huskihl
    It should help if the filter is clean and free of oil. As it gets plugged, their looks for an alternative way in. Grease helps
    bear 1998 and Ronaldo like this.
  6. Ronaldo
    Ronaldo
    I grease all of my 2 piece filters where they snap together. Pic#1 and 2 is the 555. #3 and #4 is a Dolmar 5105.[​IMG][​IMG][​IMG][​IMG]
    Sent from my SM-G930VL using Tapatalk
    M2theB, huskihl, Nixon and 2 others like this.
  7. Nixon
    Nixon
    West Sunbury,Pa .
    Do like Ronaldo suggested ,and it should eliminate the fines from the horn . I do it on all my saws ,regardless of make ,or model . Also , a really well maintained chain goes a long way to help with this problem as well .
    Sandhillbilly, M2theB and Ronaldo like this.
