450Rancher II
Discussion in 'Chainsaws and Power Equipment' started by TomC, Aug 22, 2018.
450Rancher II parts list?
  1. How to get the parts list
    0 vote(s)
    0.0%
  2. It was leaking bar oil, but I think I fixed it
    0 vote(s)
    0.0%
  1. TomC
    TomC
    Lodi, OH
    I recently got a 450Rancher II and would like to get an exploded view with a parts list. The operator's manual lists 445 II, 445e II, 450 II, and a 450e II. It doesn't list the Rancher. When I tried the Husqvarna website, it wouldn't recognize the 450Rancher, only the 455 and 460 Ranchers.
    Chvymn99 and Marvin like this.
  2. Canadian border VT
    Welcome TomC .. Had 1 gave it too friend.. Kept 460.. 5 years or so ago., it still runs..
  3. Marvin
    Marvin
    Huntingdon, Pa
    Welcome TomC. I dont know much about the 450 rancher but I'm sure you'll get the info you're looking for from someone. There's a whole lotta knowledge around here.....:thumbs:
    Camber, Chvymn99 and TomC like this.
  4. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I believe that the only difference in the 450 rancher and the 450 is the different part number for the rancher bar.
    I bought my 450 at a dealer, and it had a husky bar. Same saw at Lowes has a farm tough bar.
  5. TomC
    TomC
    Lodi, OH
    Thanks for the welcome.
    Camber, Chvymn99 and Marvin like this.
  6. TomC
    TomC
    Lodi, OH
    Thanks for the welcome!
  7. TomC
    TomC
    Lodi, OH
  8. TomC
    TomC
    Lodi, OH
    That makes perfect sense. The manual doesn't list the Rancher, but does list the 450 II. I know it is not a 450e II. I appreciate your input. Thanks, TomC.
    This was suppose to be a reply to Mwalsh9152. Maybe I will learn how to use the reply someday. LOL.
  9. Chvymn99
    Welcome to FHC .... :handshake:...
    Marvin, Camber and TomC like this.
  10. chris
    chris
    SE WI
    Crack the oil tank cap lose at end of use ( and re tighten) pressure does build a bit in there. Also clean out your bar slot and make sure the little oil port is clear in the bar as well as behind the shield plate - that little oil slot will accumulate saw dust blocking flow. Personally I port the bar oil hole to a slightly large size as well as creating a tapered slot to the port- not all the bars oil ports vs saws line up perfectly - leads to a back pressure which when you shut down saw causes oil to ooze out.
  11. TomC
    TomC
    Lodi, OH
    Thanks. I will start cracking the bar oil cap. The bar ports were cleaned out. I found that the bar oil rubber tube from the pump to the slot was not seated properly. It has a Christmas tree like rubber gasket arrangement on the bottom of the part that connects to the pump. It is suppose to seal into a hole to the bar oil container. After I reseatded it. The leaking apparently stopped. I will run the saw for a while and let you know if that fixed the problem or if the leaking reoccurs.
    Chvymn99 likes this.
